hi i have a denford cyclone with a 2.2kw (3hp) motor . i need a bit advice on technique.
i have an issue when boring
i have a part made from aluminium that has a 54mm hole in it 40mm deep.
my boring bit has a 16mm shank and needs a 20mm hole
so rightly or wrongly i first bored 10mm drill bit
then used a 20mm slot mill to drill to 20mm
then the boring bar to edge it out to 54mm
it does struggle a bit with the 20mm slot mill in the tool holder and seems a long winded way to do it.
i have seen some ceratizit ecocut tools which your can drill with then use it to bore out the diameter .
but for 40mm deep i would need 18mm cutter @2.25d length and im not sure of the hp requirement to use this tool .
any suggestions on a better technique or tool would be appreciated.
i only turn aluminium
regards
regards
