I don’t have lot experience with steady rests.
I have two propeller shafts diameter about 200mm/ 8inch, which I should shorten 400mm and make thread inside etc, so I can’t use tailstock. Length is about 4000mm, so I think I have to use two steady rests.
We have two C-type steady rests, which go small enough. Side is open. One roll is straight down, one is at back and top roll is 15 degrees to front from centerline.
Steady rests are pretty much like in this picture, but it’s all solid, not swiweling top.
Steady Rest Type 5 -- H. Richter Vorrichtungsbau GmbH, Germany
I’d like to ask, is that kind steady rest safe to use without worry that shaft could ”jump” out of open side?
I think that it would be safe, but older coworker with more experience with that lathe thinks it might be unsafe. But he’s used those steady rests with tailstock, not without.
On right picture is same kind setup, with similar type steady rest.
SAFOP - equipments
SAFOP - equipments
