Turning long and thin rod
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Nov 2019
    FINLAND
    40
    22
    Default Turning long and thin rod
    Hi,
    I need to turn fairly long and thin bar. I’m thinking how should that be done. Finished product is mostly 8mm thick and 150mm long. However there is one shoulder with diameter of 11mm. If I were to make it from 11mm stock what might be the correct way of turning this? Some sort of steady rest which would be the opposite side of the cutting tool would be good but I only have huuuuge rest which doesn’t suit into this purpose.
    I was thinking of two options. Have that 11mm shoulder machined separately then press fit it afterwards. Then it could be made from 8mm stock. Or machine short distance at a time and then move that part out from the jaws and continue another distance. Neither of those sounds very good, but is there any other choice?
    Thank you in advance
    Jun 2019
    Missouri
    146
    68
    102
    Collet, turn short distance, advance, repeat.
    Flip end for end and finish the head.
    If you need to, add a few m.m. to the skinny end and drill a center and use a live center.
    Easy peasy.
    PS, the steady rest will only get in the way.
    Dec 2008
    New York
    10,234
    2656
    swiss machining, stick out, turn it, then stick out some more and turn some more
    swiss lathes do this automatically some how, on a manual lathe you manually do it
    Jan 2007
    Norfolk, UK
    19,017
    14526
    14620
    use a roller box, - like this YouTube
    Exactly the sort of job a box tool's made for
    Aug 2008
    Sussex, England
    3,406
    12
    750
    I think Thunderjet is optimistic. On a skinny piece like that machine a bit, stick out a bit further and machine more pretty much guarantees that it will climb over the tool and go prestzel before you have finished. Even with teeny weeny cuts and a centre.
    As Limy says classic reason why roller boxes were invented.
    If you have a four way tool post or a QC system capable of mounting more than one tool without the carriers or shanks interfering a poor boys substitute for a roller box is an L plate style steady on a suitable shank held just behind the cutting tool. Not as strong as a proper roller box unless you go more serious on the engineering than a one time job is worth but it will get the job done. In two cuts rather than one. Or, if you don't have to get over that collaer mid cut, you could use a right size bush which probably will get the job done in one cut if well lubricated.
    Clive
    Norfolk England
    2,304
    2644
    1721
    Quote Originally Posted by Limy Sami View Post
    Or a pointing toolholder
  7. Likes Limy Sami liked this post
    Feb 2012
    The warm desert of Phoenix Arizona
    1,457
    330
    508
    A seriously old school approach would be with a follow rest and light cuts.
  9. Likes tech610 liked this post
  10. #8
    Mar 2005
    Northwest Indiana
    4,275
    906
    879
    150mm long is only 6"... I'd think you could just stick it halfway in the chuck and turn half, then turn it around and turn the other half easy peasy. Not THAT bad of a L to D ratio if you do it half and half and use a good sharp tool with a very small nose radius. Could actually probably do it in one shot unsupported.
  11. #9
    Oct 2005
    15,989
    What is the lathe to be used ?
  12. #10
    Sep 2004
    Sonora , Calif
    584
    120
    122
    Look up Frank Ford follow rest.
    I would also use a box tool.
  13. #11
    Sep 2018
    New Jersey
    16
    29
    I would use a follower rest.
  14. #12
    Jan 2007
    Norfolk, UK
    19,017
    14526
    14620
    5A W&S with a 75 HP motor.
  15. #13
    Apr 2011
    Nebraska
    1,254
    1800
    369
    If you can get away with a two piece I'd just drill an 8mm hole in the 11mm stock and insert the 8mm bar in to it. You can do a heat/cool fit, Loctite retaining fluid, pin it, etc. No messing around with trying to get a long thin bar on the lathe.
    JMHO
    -Ron
  16. Likes Limy Sami, Peter from Holland liked this post
  17. #14
    Mar 2014
    Nebraska
    373
    42
    233
    I agree. If a press fit head is permitted why even bother trying to turn it? Order TGP 8mm shaft, machine the head, press it on, call Bob your Uncle to finish it.
  18. Likes Limy Sami liked this post
  19. #15
    Jun 2012
    Michigan
    4,804
    4407
    2907
    That's pretty cool, but I'm boycotting them. Twice they mention that it's marketed toward engineers.
    What the fuck do engineers know about machining? At least 99% of them anyways.
  20. #16
    Jan 2007
    Norfolk, UK
    19,017
    14526
    14620
    Quote Originally Posted by Mtndew View Post
    Ah/ that is more to do with translation, in the USA and on the tools guy on the shop floor is a machinist, the guy at the drawing board the engineer.
    In the UK the guy getting his hand dirty is often called an engineer, the guy on the drawing board a draftsman or designer.
    So when tangi Flow say it's marketed towaeds engineers, they mean the guys actually using the tool
    Confusing isn't it.
    Oh and boycott who you like
  21. Likes MetalCarnage liked this post
  22. #17
    Oct 2005
    15,989
    Confusing isn't it.
    Or the one blowing the whistle on the loco....
  23. Likes Limy Sami liked this post
  24. #18
    Jan 2007
    Norfolk, UK
    19,017
    14526
    14620
    YouTube
  25. Likes digger doug, 4GSR liked this post
  26. #19
    Oct 2005
    15,989
    Rutt - Roh
    Limy better explain the term "bespoke" as well.....
  27. #20
    Jan 2007
    Norfolk, UK
    19,017
    14526
    14620
    bespoke meaning - Google Search
    bespoke
    /bɪˈspəʊk/
    adjectiveBritish
    adjective: bespoke
    made for a particular customer or user.
    "a bespoke suit"
    making or selling bespoke goods, especially clothing.
    "the bespoke tailors of Savile Row"
  28. Likes digger doug liked this post
