Turning Long Thin Walled Tubes
Results 1 to 11 of 11
    Apr 2015
    New York
    10
    Default Turning Long Thin Walled Tubes
    Hi All,
    Looking for some tips on turning some long thin walled tubes. I am running into a few issues.
    First is that the tubing is bowed, these tubes are about 36" long and 1.5" diameter. Some are better than others but ultimately its out of the question to find perfectly straight tubes. I have a follow rest for my 13x36 Clausing lathe but the tube nudges my whole carriage to the side as the high spot passes. Is there a way to shim the carriage back to tight tolerance on the ways? Or are these just forces a lathe isn't designed to take?
    let me know if anyone has any ideas..
    Sep 2006
    SW Wisconsin
    557
    38
    144
    Cut toward the tailstock, you will be turning it straight as you come to the high spot. Get it straight then you do what you want.
    Ed.
    Jun 2012
    Michigan
    5,097
    4655
    3072
    Quote Originally Posted by juggaloslaya View Post
    Hi All,
    Are your gibs tight?
    Aug 2015
    Illinois
    1,489
    1092
    635
    Can you straighten them before turning? Heat treat shops often have straightening presses.
  5. Likes Matt_Maguire liked this post
    Jan 2003
    Columbia Missouri
    816
    40
    130
    If the carriage is being moved by the high spot you need to determine where it is loose, and why.
    What usually happens is the tubing bends away from the bit, and the diameter iws increased in the middle. The purpose of the steady rest is to trap the portion of the tubing just cut between the steady rest and the bit. This allows the diameter to cut the same along the length. This should also eliminate the high spot from being able to push the carriage. You need to be taking a full diameter cut at the tailstock end, then adjust the steady rest to touch this, then make the rest of the cut. It sounds like you have the steady rest before the cut, so it is being pushed by the high spot.
    How is the tail-stock end of the tubing being supported?
    What is the tubing material?
    What type of bit? Carbide? HSS?
  7. Likes Hopefuldave, StinkyDan liked this post
  8. #6
    Dec 2012
    AUSTRALIA
    2,840
    12
    920
    Fill the tubes with Cerro metal ,melts at boiling water temp for reuse.
  9. #7
    Aug 2004
    Virginia
    2,456
    179
    971
    You might try driving a mandrel into the tube. This would straighten and support it.
  10. Likes petersen liked this post
  11. #8
    Nov 2019
    CANADA
    Ontario
    65
    9
    6
    idea #1 tighten the lathe down or fix how loose it is.
    #2 most tubes are nowhere near as straight as they seem to be, ever.
  12. #9
    Aug 2007
    Great Lakes USA
    227
    27
    34
    Also make sure you aren’t distorting/deflecting the tube in your chuck/collet. I turn full length (usually about 26”) thin stuff between centers pretty frequently; made a faceplate with a drive dog type thing, and that helped quite a bit.
  13. #10
    Oct 2005
    17,314
    Nudging the cross slide ?
    Use a smaller nose radius to lower the cutting forces.
    Also get rid of most "lead angle" or what ever you call it, and go with a almost
    square to the cut insert angle.
    Also, if you can, go with a positive rake to again "lower the cutting forces"
  14. Likes J_R_Thiele liked this post
  15. #11
    Jan 2003
    Columbia Missouri
    816
    40
    130
    To followup on Digger Doug's comments.
    Consider grinding a bit just for this cut so you can easily control and modify the nose radius, rake angle, and angle of the cutting edge. Carbide "pushes" against the work more than HHS does, so try going to HSS. Even better yet, get some Tantung G. or one of the other cast alloy blanks.
    Cast Alloy Lathe Tools
    If you are going to use carbide, consider some of the high rake inserts designed for aluminum.
    One last thought. If nothing else is working for you, slow the speed down, hone the edge as sharp as you can get it (diamond if a carbide bit) and slather the bit and the work with Moly D tapping fluid.
  16. Likes digger doug liked this post
