Material from MMC, billed as "Easy-to-Machine Glass-Mica Ceramic"
I've been asked to bore a 1/4" diameter thru hole in a 3/8"diameter rod. It only needs to be about 1/2" long.
I did read up in the forums and ran a lot of pecks, low feed force, and cleaned out the swarf frequently.
I did manage to drill the hole fine, but the part cracked lengthwise.
I tried different speeds, step-drilling, drilling vs. boring, etc. with pretty much the same result. I've been using a normal steel collet but wondering if I'm over-clamping or if I should just use a brass or plastic collet.
I did clamp it pretty hard at first, so wondering if I fractured the whole length of rod at first and my subsequent issues were from that.
I've been using carbide tooling, it's what I have and it's hard to justify diamond for one part since I don't even know if it's a tooling issue or clamping issue.
Also, I'd welcome recommendations about drilling and then parting off or cutting to length first then drilling.
thanks folks, this one has me frustrated.
