Hi All:
I'm with Edwin Dirnbeck on the notion of cylindrical grinding them in.
In my opinion, this is a hopeless task, trying to turn them.
I don't think you can exert enough pressure to get an 0.040" wide cutoff blade to plunge into HSS without eventually pulverizing the tip of the tool from the pressure.
There comes a point when it's just way too hopeful and ambitious to try to do a job for which you don't have the proper gear.
Now I'm all for stretching the envelope when it makes sense to do so, but I doubt that this is one of those cases.
However if you DO insist on trying to beat this into submission, you will likely have best success with a narrower blade dropped in maybe 0.005" at a time . then pulled back out, then shifted to the other side of the slot, then dropped in 0.005" deeper, then pulled back out and shifted back etc etc until you get to the bottom of the slot.
Make the tip of the tool only just barely longer than the depth of the groove so you can exert some force on it without buckling it, make sure your tool tip is tiny bit below center, do it slowly and without cutting oil, but maybe with a smidge of Moly Dee or Rapidtap and pray a lot as you try.
But this is literally a 20 minute job with a toolpost grinder or a cylindrical grinder...I'd spend more time fucking around trying to make the cutter than I would grinding the job complete.
So I encourage the OP to either rig a toolpost grinder (even if it's jerried together from a die grinder, a 2 x 4, and a couple of hose clamps) or farm the job out to someone who can do it without having to tear their hair out.
Cheers
Marcus
