Turning a rough finish on purpose
Results 1 to 10 of 10
    Jan 2018
    New Jersey
    18
    89
    Default Turning a rough finish on purpose
    Hey guys,
    I have a Nitronic 60 tube about .500"dia by 2"long. When machining the OD to final size I would like to end up with a Ra around 125. Any suggestions on tooling, feeds, other odd ball ideas? We've currently tried increasing the feed rate while barely touching the OD.
    Sep 2007
    Washington
    5,277
    202
    1607
    Try for a 32 finish, then you will get a 125 .
    I suppose you could calculate scallop height for various tool nose diameters and feeds, and get 125 micrometers per the math, then see what it comes out as. But, surface roughness takes many forms, so if you are actually trying for a specific value, it helps to know what characteristics are desired.
    Regards.
    Mike
  3. Likes Ray Behner, TeachMePlease liked this post
    Dec 2014
    CANADA
    British Columbia
    1,282
    361
    589
    Use a threading cycle with the calculated desired scallop height. You could also do a pseudo knurl with multi-start threads.
  5. Likes edward.santos liked this post
  6. #4
    Jan 2009
    Maine, USA
    203
    100
    92
    https://www1.mscdirect.com/images/so...faceFinish.pdf
    With a 1/16" tip radius you're around 0.016"/rev or with a 1/32" radius around 0.012"/rev or with a 1/64" tip radius 0.008"/rev. I know which one I'd go with on a 0.5" OD tube.
  7. #5
    Mar 2007
    Milwaukee
    433
    345
    203
    Sounds like a phonographic finish. We used a square insert with a 1/32 rad. and feed it around .030 IPR. We used this technique for facing a sealing surface on a flange.
  8. #6
    Jun 2013
    305
    149
    129
    Try a carbide cutter whose once-sharp edge has been chipped off irregularly.
  9. #7
    Jan 2019
    Arizona
    757
    66
    251
    Quote Originally Posted by edward.santos View Post
    Hey guys,
    your going to have to take at least a few thought per side for it to work., all insert rads will give you a 125 finish or a 250 finish or a 63 finish. finish is only adjust by feed rate nothing else.
    if your breaking the tips or wearing them down on harder material like you have, your going to have to use a bigger rad tip. a .015 or .032 should work fine
    how are you checking the finish? visual or meter, if you have a profolometer(sp) just double your feed rate and see what it reads compared to what its currently running.
    if you are checking visual a comparator helps with a sample finish gage and compare it to the part your running.
    remeber with the visual gages a mill finish, lathe finish, grind finish all look different. good eyes help
  10. #8
    Jan 2005
    CANADA
    Saskatchewan
    10,236
    1395
    3688
    Use a super slow surface speed and a dull insert. Used to do this all the time when prepping for metallizing. Also raise the insert just a tad above centerline height so it rubs real good
  11. Likes edward.santos liked this post
  12. #9
    May 2012
    Pittsford, NY
    1,055
    726
    680
    Could you anneal a set of knurls, turn smooth, grit blast heavy, reharden, and take a single pass across? Might take a few to get the roughness right, but once you hit it it would be repeatable.
  13. #10
    Jan 2018
    New Jersey
    18
    89
    Quote Originally Posted by JCByrd24 View Post
    Thanks JCByrd24, that chart was really useful.
