Turning square shafts - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21
    Virginia
    20,086
    7561
    11969
    Quote Originally Posted by winger View Post
    I haven't tried it on SS but on cr steel I use a 1/2 square HSS . Turn the cutting edge 30 to 40 degrees and go almost full cut , slow spindle speed and very slow feed rate. If the cutting tip is in solid stock it doesn't pound. Leave just enough to finish to size.
    That has a lot of merit.
    It is one of the things Tantung-G is very good at.
    But so, too ordinary Carbide.
    Joe P. used a full width cut (in round, but also stainless) to demonstrate just how SKINNY and LONG the "end plunge" turning technique could command.
    Extended Small Diameter Turning -- No Problem - YouTube
  2. #22
    May 2003
    5,604
    23
    815
    termite you have never made a single part on any machine! You are in a panic over the racist post you made with your forum ID Monarchist, that you were banned for.
    I think you are going to loose some sleep tonight, Grand Cyclops of the PM forum!
    And a little more from a working pro!
    termite, it now makes sense your personal attacks on me! You are a stupid fool, dont you fucking know racist like you, and your stupid helpers are public enemy No1, in this woke era?
    You and your cub scout Webelo clowns, are a racist enclave! With you being the leader claiming to be law enforcement, and your junior cyclops being a supposed cop and forum moderator, that tried to intimidate me with homophobic shit!
    This cant be made up! If you jerks didnt have this, what, you become, a racist lawn mower theft ring?
    termite I dont know your name, or ever want to, but you and your racist helpers best make a quick exit, or you sink this forum!
  3. #23
    Sep 2015
    Ohio
    1,802
    1185
    1940
    Fuck dude. You’re chasing him around this forum like some kind of jilted lover.
    Get a life. No wonder people are leaving.
  4. Likes dalmatiangirl61, digger doug, GregSY liked this post
  5. #24
    Feb 2011
    BFE Nevada/San Marcos Tx
    2,989
    3028
    1898
    Quote Originally Posted by Booze Daily View Post
    I think Donie is vying for first place in the nutjob category, he is jealous of termite holding the title for so long, or maybe its just too much cheap wine and wild turkey, hard to tell.
  6. Likes GregSY liked this post
  7. #25
    Oct 2005
    21,982
    If you pre-turned a short section, a box tool with rollers set on the round portion (back of the cutting tool) could then be employed, you could make good time on it.
  8. #26
    Jan 2005
    Houston
    7,027
    1286
    4017
    Yeah, I gotta say...Donie sure seems like he has some kinda unhealthy attraction to Thermite. I'm sure sick of seeing it. Here's the thing, Donie - no matter how much you like someone, no matter how much you lie awake at night having tortured thoughts about them, no matter how much you just know they are THE one for you....if they don't like you back that way, it's not gonna happen.
  9. #27
    Oct 2005
    21,982
    Quote Originally Posted by dalmatiangirl61 View Post
    Funny, I've never seen Thermite ever use the race card.
  10. #28
    Oct 2012
    NE Ohio USA
    735
    153
    285
    Ok, back to the thread:
    When turning square stock, I have often been successful by wacking off the corners in one pass (tip of the cutter beyond the flats in the stock). Slow the speeds and feeds down to a crawl and rip off the corners using a zero to slightly positive rake tool. with 0 to 10 degrees flank angle. You should get a continuous ribbon chip that is not blue.
    Once the corners are gone then resume normal speeds and feeds (perhaps with a different cutter). The interrupted cut is what kills the process. Get past that and your home free. Hope this helps.
    Best Regards,
    Bob
  11. #29
    Jan 2007
    Flushing/Flint, Michigan
    10,543
    614
    8522
    Turing square to round is brutal. It is like turning splines but much worse.
    You are going to take a hell of a beating but you want to cut and hold size when that beating is done.
    Positive tooling will not take the beating, huge neg rake not so happy on size control if the end small passes.
    Do you have a tooling type sales or application guy of deep experience that likes you?
    Bob
  12. #30
    Virginia
    20,086
    7561
    11969
    *yawn*
    Lathe tool has an easier life if you first forge, rough saw, or mill the ends to an Octogon. At least.
    Just sayin'
