TonyS
- Jan 25, 2009
- California, USA
I'm considering two 5hp motors for use on a log splitter with a 13gpm pump. Leeson #131641 is a close coupled motor with a 7/8" shaft. Leeson #131616 is heavier, has a 1 1/8" shaft, and is more expensive. Will the 131641 will work just as well driving the 13gpm pump on the log splitter? Or is there is some performance advantage to the 131616 and if so is it significant enough to warrant the extra expense for this application?
Tony
Tony
