We have a basement without walls. She wants to finish part of it, and I want to put a shop down there. It MIGHT be possible to do both with some planning. And before anyone asks how Leroy Gibbs plans to move his boat (running gag on NCIS), YES this is garden level with an OH door.
I'm more familiar with woodworking and have done some welding, but a machinist I am not, least not yet. Can anyone advise me on the TYPICAL sequencing of operations in metal machining? I'm sure there will be exceptions, I just don't want to be criss-crossing the floor between machines.
My guess, based on woodworking, would be sheet shears, bandsaw, chopsaw, and plasma cutter to break down stock, mill for surfacing and linear shaping and boring and broaching and tapping threads (with machine off and turning the chuck by hand and letting the threads pull the quill as they are made), lathe for turning and cutting threads, bench/angle/die grinders, files, sheet bender, tube/rod bender, sheet shrinker/stretcher/hammers/dollys/english wheel, hardening/tempering, then finally to the arbor press, welder, paint booth, and nuts/bolts/screws.
Is that about right or am I way off? Am I missing anything major?
