UHMW bushing help / advice
Likes Likes:  0
Results 1 to 8 of 8
    Mar 2011
    Wilmington, delaware
    117
    17
    22
    Default UHMW bushing help / advice
    Next week I am suppose to make a couple hundred bushings ( washers?) out of 1 inch diamter UHMW. I have not seen the print yet, but the material came in today and is rather soft and flexible. Material is in 4 ft sections and rather "bendy".
    I have never used solid UMHW that is this small, most of what I had done was with 2 inch and larger tubing. I am concerend with the dimesional stability of the material and how much it will push and whip when using it in a 3jaw chuck.
    I was told that the final pieces will be .960 (+0/- 0.010) inch diameter, have a clearance hole for a 5/16 pin drilled through the center, and the piece will be 0.094 (+/- .010) inch thick.
    I have read that the material should be turned or drilled with hss and a surface speed of 600 to 1100 fpm. I also read that it materials "grows" after machining and that the material will "suck" the drill into the body of the material.
    My initial plan of attack is to turn down 6 to 8 inch sections at a time, then start with a Q drill and work up from there for the clearance hole, then part off the pieces.
    I am wondering if the pieces will grow overnight? I am trying to get a little piece to experiment with over the weekend.
    So any suggestions for feed/ speed, procedure, tool bit shape, etc. will be appreciated.
    Dec 2010
    Western CO
    372
    19
    100
    We use this stuff regularly. Fast rpm s, hss cutters. Cuts like butter. It is quite forgiving material.
    Mar 2012
    Quebec, Canada
    627
    88
    201
    yes nits true that the material will move after you machine it but if you only get rid of 0.040 od and you drill a hole it should be fine on this point. i personally find out that running 1" at around 1200 1500 do a relay nice shop with a HSS cutter. make it realy sharp and finish the grinding with a fine stone. for the drill its not like Delrin or Nylatron thos one will eat your drill if there is already a hol;e in it but iof you are doing the hole 1 shoot deal with a drill its going to be fine.
    Toronto,Canada
    78
    38
    26
    Quote Originally Posted by Krovvax View Post
    I totally agree, and as far as bar whip why not machine a ring to fit the stock and the spindle dia?
    Jul 2004
    Vicksburg, MS
    4,936
    30
    259
    I'd suggest finding a drill, or grinding one, that will get to one size in one shot. Going back for a second cut is a bad idea, it will grab and the drill won't move, the material will. Like everyone else said, sharp HSS with generous radius and, at least in my experience, feed the tool like you have a lady waiting. I get fantastic surface finishes that way.
    Jan 2012
    Missouri
    220
    398
    69
    Regarding the parts growing after machining, I would recommend machining just a few pieces and allow them to stabilize over night. Then you'll know if any compensation is needed.
    Regarding bar-whip, we use spindle liners.
    Brian
    Dec 2007
    Iowa
    230
    Machining is the easy part. It's deburing that will make you pull your hair out!
    We use our hardinge DSM/DV 59's for deburing. SUPER SHARP tooling. set your stops and take quick jabs at it, if you go slow like machining steel you will just push the material around. Good luck, cause until you get it perfect it will suck.
    Mar 2011
    117
    17
    22
    Thanks for everyone's help. The material cut like taffy and I my pieces were covered the whole range of tolerances but at least it it over.
