david n
- Apr 13, 2007
- Pillager, MN
I want to hang some unistrut over a machine to lift the 4th axis on/off the machine. (And before all you safety nazis chime in, I'm only lifting around 100lbs and I will be the only one doing the lifting.) There are trolleys that fit right inside of the unistrut channel. I'm thinking of two rails and one cross beam to make my "crane". I'll go up in the attic and put a strap up/over the bottom web of a rafter. Anyone use these little trolleys for a similar application?
