Themanualguy
- Aug 14, 2014
- Wollongong, Australia
Gday Gents
I’ve done a search but all replies were machine tapping, not related to the method I’m using.
Customer has knocked back some cylinder head caps with 3/4” UNF ( UNO Port ) threads that I made recently due to a sloppy fit in the threads.
I tapped the thread by hand using a brand new Sutton 3/4” UNF Gun Tap, in my lathe using a centre to guide and keep the tap square.
I’ve inserted a new M36 threaded boss and tig welded it in and re-drilled and re-tapped the port threads but the same thing has happened.
Customer requested I try their taps.
Decent condition HSS Sutton Hand taps. Result is no better.
I’ve done some measuring of the various taps and sample fittings using a thread mic for pitch diameter.
Sutton Gun Tap 18.02mm pitch diameter
Sutton Hand Tap 18.06mm
Standard 3/4” UNF pitch diameter according to engineers black book 18.01mm
Sample fitting 17.84mm
I’ve made a simple 4140 thread “gauge” using a 16 TPI full form Iscar insert and threaded until the overall OD measured 19.05mm, but the resulting pitch diameter is 17.92mm.
I’ve used a dial indicator to measure the side to side “play” of the various male threaded items in the holes.
Generally all have 0.3mm radial play measured right next to the mouth of the hole, with indicator tip square and central to the tap, thread gauge and hex head fitting.
From the on set it’s easy to say their fittings are sloppy but I’ve been doing UNO tapped ports for them for years without an issue. I will ask if perhaps the supplier has changed but I don’t want to accuse them of buying junk fittings.
They have requested I screwcut them using an internal threading bar which I will do for this job, but I don’t want this to set a precedence for the future that a UNF Tap won’t produce a thread with enough precision to be used as a hydraulic port.
Can anyone shed any light on;
- why are none of these taps cutting to size.
- any tips to achieve higher precision tapped holes for hydraulic ports
- any tips regarding making your own thread gauges using full form threading inserts.
Material is plain carbon steel.
Using threading oil as lube.
Using standard bar type tap wrenches
Manual lathe
Hand tapping, reversing tap every 4-5 turns to break at any chips.
I don’t have CNC so threading Milling is not an option.
Part is 13” x 13” x 3” thick hydraulic head plate so screw cutting a 3/4” UNF thread in the bore is not an easy feat using my large lathe.
Thanks Gents
Manual lathe
Thanks Gents
