Unusual Summit Lathe - Does anyone know year?
Results 1 to 4 of 4
    Mar 2019
    North Carolina
    25
    26
    Default Unusual Summit Lathe - Does anyone know year?
    I found an ad for a 19 x 48 Summit lathe that has plastic knobs where most Summit lathes have metal knobs (see the round black knobs in the pictures). The knobs are consistent throughout the machine, so they seem to be original. Does anyone know the age or have more info on this model?
    Thanks.
    Dec 2008
    Vt USA
    6,799
    748
    2356
    Summit never made a lathe, ever.
    They were an outlet for many machine tools from any of many manufacturers.
    You are looking at the Tuesday offering. On that particular Tuesday, Lathes came with plastic knobs and wheels.
    Or, a previous owner made the switch.
    Either way, ignore it, there will be no resolution to a dilemma that is yours alone.
    Mar 2019
    North Carolina
    25
    26
    I understand that Summit is a re-seller, rather than a manufacturer.
    Jan 2005
    CANADA
    Saskatchewan
    10,236
    1394
    3688
    Summit may only be a name, but they definitely had their own design, wherever they shopped it out to. Yugoslavia was a common source for that model.
    You might have to look closely at it in person to find the year of manufacture on a very small nameplate. Looks similar to mine, which are of 1980's vintage, although mine doesn't have plastic knobs. Most likely plastic would be somewhat newer as it could be cheaper. My WAG.
    Perhaps the main wearing item to check would be the forward, reverse and brake clutch packs. If the machine is regularly adjusted to keep these clutches at a nice 'snap in' feel, and enough brake drag to stop the spindle in a few seconds, then they shouldn't warp all to hell, and create nuisance dragging that could make the spindle sluggish to engage and release.
    There is a cover on the back of the headstock that is opened to adjust these clutches. There is a dog pawl to retract and then a ring to adjust on each clutch pack. Should only ever need to adjust one hole or two. They are fiddly to adjust, as the adjustment of one of them can seem to affect the center neutral position, when the brake clutch becomes active. Don't overtighten. The machine spindle should be able to shift smoothly from forward to reverse without pausing at about 220 rpm. Handy for threading near a shoulder. Adjust one clutch too tight and you'll have to get really rammy to make the transition, and that's not the way to operate.
  5. Likes 4kinetic liked this post
