US made engine lathes that cut metric threads?
Page 1 of 3 123 LastLast
Results 1 to 20 of 60
    Jul 2009
    Peoria, IL
    11,736
    51
    8984
    Default US made engine lathes that cut metric threads?
    I need a better engine lathe in the 16x40 inch range. I'd like to have something US made, like a Monarch, American, Lodge and Shipley, etc. However, I need to be able to cut metric threads.
    I understand that any lathe can cut any threads with the right change gears. But, did any US lathes cut metric threads without the need to change gears? I've done a bit of searching, and it seems like maybe some of the later South Bend lathes can cut metric.
    Are there any models I should look out for? My current Taiwan special can cut US threads from 1.5 TPI up to I think 100, plus metric and DP threads, and it can cut 13 TPI, all with no unbolting of gears.
    May 2002
    South Central PA
    13,619
    2280
    3535
    Not USA, but how about British? Colchesters will cut metric and DP.
    I'm not sure enough to bet money on it, but when I was buying my Polamco new in 1980, it was unanimous opinion among the dealers that there were no USA made lathes that cut metric threads, which was one of my buying criteria. Canadian Standard Modern might also.
    Jul 2009
    Peoria, IL
    11,736
    51
    8984
    I guess the US makers were pretty well out of the game by the time cutting metric threads was really a concern for US buyers.
    Did the US machine builders ever make metric versions for export like every company makes inch versions for us to import?
    Jul 2004
    Houston, TX USA
    30,083
    Hendey for certain, Pratt & Whitney for certain like way back. P&W filled German armories with USA made machines prior to 1900
    Thumbnail is Hendey from about 1920
    Dec 2008
    Vt USA
    6,800
    748
    2356
    I don't get the reluctance to change gears.
    My Mazak Ace changes in less than 5 minutes, and the Weiler LZ330 the same. A spanner is the only tool needed, and I keep those on the headstock.
    Call me lazy, I can't see the reason to need a lever to do the same change over.
  6. Likes steve-l, Monarchist liked this post
    Jul 2009
    Peoria, IL
    11,736
    51
    8984
    Once you change the gear, then what? Those machines probably have a nice chart and factory made gears.
    Nov 2004
    Birmingham, AL
    13,229
    6615
    2561
    My 1918 L&S has a metric change gear chart. Have never used it, but it looks like you swap the spindle gear.
  9. #8
    Dec 2008
    Vt USA
    6,800
    748
    2356
    Quote Originally Posted by ewlsey View Post
    Change the gearing, do the task, then put the "familiar" gears back. It's easy.
    And yes, A good reference is a must. I tend to use the printed data in the service and operation handbooks. The placards are hard to read on both machines.
    It's a lot like making an op sheet for any part production. Setting up the machine is just one of the operations.
  10. #9
    Sep 2008
    CANADA
    Nova Scotia
    294
    19
    125
    Quote Originally Posted by CalG View Post
    I do.. my Colchester changes from metric to imperial by flipping a lever in less than a second. I know the changing of gears isn't a big job but it's just another thing to do...
  11. Likes MerlinXPV liked this post
  12. #10
    Dec 2008
    Vt USA
    6,800
    748
    2356
    Quote Originally Posted by isaac338 View Post
    Yep! Just another thing to do. Such is life. I try to appreciate every action. It gives me a warm fuzzy feeling when I do.
  13. Likes M.B. Naegle liked this post
  14. #11
    Mar 2013
    Cerritos, CA
    386
    129
    147
    New LeBlond
  15. #12
    Jul 2009
    Peoria, IL
    11,736
    51
    8984
    Quote Originally Posted by Lanso View Post
    New LeBlond
    Made in Taiwan.
  16. #13
    Dec 2016
    Kentucky
    220
    34
    71
    In the process of getting prints to make my own transposing gears for my 12-30 hendey. Hendeyman has them and he said he can make the gears for you if need be.I'm opting to make them for the experience even though it would be more cost effective for me to just have them made. One set covers multiple sizes. 12,14 16, is one and I think 18,20,24 is the other.
  17. #14
    Mar 2013
    Cerritos, CA
    386
    129
    147
    Made in Taiwan.
    I was afraid of that.
  18. #15
    Mar 2005
    Kansas
    7,578
    438
    3494
    LeBlond Regals have been offered with metric threading for decades. The later ones require sliding one gear to choose standard or metric.
  19. #16
    Nov 2004
    Birmingham, AL
    13,229
    6615
    2561
    A guy I know has a Cincy Hydrashift with metric gears, too. Just have to flip the spindle and banjo gears over. Really nice machine.
  20. #17
    Feb 2013
    727
    490
    404
    The Graziano SAG's aren't US made but seem plentiful and very well made. Would fit the bill pretty well. Also seem less beat on used as I am guessing they were pricey new and didn't go to the 200lb gorillas to use.
  21. #18
    Feb 2007
    Aberdeen, UK
    3,620
    1251
    1388
    A Colchester is not much (if at all) of an upgrade from a half decent Taiwan made lathe.
    I have a pretty low opinion of Colchester lathes - Colchester and Harrison were the two "commodity" British workhorse lathes, of similar (average) quality, but of the two the Harrison is by far the nicer machine to use.
    There are a number of European lathes that match the old American built ones you are looking for, that have the same kind of universal gearing as your modern Taiwanese lathe.
  22. #19
    Mar 2006
    Wisconsin
    1,090
    14
    371
    My Sheldon MW-56-p is capable of metric and imperial threading "when properly equipped". All the M series lathes could be purchased with a single gear to be changed out for metric threading. It's a quick change gear that takes all of about 30 seconds to change. I have no idea how popular the option was or how many change gears were sold after the fact. I doubt it was very popular option in this country until the 1980's. That's about the time the auto industry started slowly moving to the metric system
  23. #20
    Feb 2013
    midlands,UK
    3,153
    1625
    1541
    Quote Originally Posted by gregormarwick View Post
    I would be interested in why a Harrison is nicer than a Colchester? I too am not a Colchester fan ,they're OK when near to new but I can only afford old ,by which time they are overpriced and worn out IMO.
