metamaterial
- Feb 8, 2019
hi,
I'm looking to get my first small granite surface plate and came across a used one that I think fits the bill but don't know what to watch out for and how much it should be worth. Can anyone give some input on it? As to how I might use it, see the final questions below.
The plates:
There are two for sale:
Plate with "496" written on its side
Plate with "171" written on its side
I think the "171" plate is DIN 876/1 flatness grade based on the yellow label on the side (translates to "usable to precision class 1", which is relatively poor as far as I see from THOME Prazision GmbH | DIN 876 - Tolerance of flatness, no idea what grade the plate "496" is.
The size of plate "171" is 450 x 350 x 65mm (17.7 x 13.8 x 2.56"). I think the other plate is the same size.
The plates have been online for at least half a year at ~$90 so I'm guessing that price is high (it's Europe so add at least a 1.5-2x "tax" over what you'd expect to pay in the US). They guy had some Grade 00 plates but they got sold.
To give you some reference points for cost, these are the cheapest new surface plates of roughly similar size but higher grade that I found on amazon and ebay:
450x450x75mm (17.7 x 17.7 x 2.95") DIN 876/0 for ~$200
WABECO Granit Messplatte Prufplatte Tuschierplatte 450x450x75 Messtisch: Amazon.de: Gewerbe, Industrie & Wissenschaft
400x250x70mm (15.75 x 9.8 x 2.76") DIN 876/00 for ~$163
Messplatte Hartgestein Kontrollplatte Granit Platte Tuschierplatte Anreissplatte | eBay
I don't think it's relevant but I'll mention it just in case--
I just got a height gauge, used, this model:
Machine DRO ME-HG-PRO-300 Digital Scribing Height Gauge n/a 300mm (12 inch)|allendale-metrology.co.uk
The questions:
1) how might I be limited by this "Grade 1" surface as I evolve and do more precise machining and layout work? You know, sometimes it's ok to buy a cheap tool, grow with it, then buy something better, other times it's just frustration and you end up buying a better tool almost immediately after using the cheaper one. To start with I will use it for aligning assemblies and laying out lines for drilling/cutting during builds of small projects in my basic basement workshop, then will use it during my build of a cnc mill (I aspire to something like what this guy did in UHPC but doubt mine will be that precise: Projektstart MiniVMC/BAZ "Elke" aus Beton (MiniVMC Part 1) - YouTube) and probably while making a mount for a binoscope I'm building (dual telescopes used like binoculars. The best d.i.y. example I've seen is: https://www.youtube.com/watch?v=akFaEhcuHcQ). Not quite optics in terms of wavelength precision, but some precision required. I also might like to try scraping at some point, maybe for making some small ways.
2) what would a good price for one of these plates be?
3) are there any things I should look at closely if I go in person to check out the plates? Any subtle but show-stopper problems in particular?
4) how bad can chipping or pitting or grooves be before I'd start getting problems (and frustration) using the plate?
5) might it be cost effective to get this low-grade plate then somehow turn it into Grade 0 or 00? (0 and 00 might be similar to A or AA but I don't find a page showing the conversion) Plate conditioning does not look really d.i.y. based on videos I saw of the process, but maybe someone has some experience in upgrading their plate and can share it.
6) is a surface plate the kind of thing you're better off buying new because if you're an inexperienced user the risk is too high that you buy an old one you think is ok but after a few weeks of using it understand that it's full of limitations and problems?
Any thoughts on all this would be appreciated.
Randy
The plates:
The questions:
Randy
