Hi
This is my 1st post on here, been a member for a bit and found it a great source of info.
I’m no Machinist but served my time as a Agri Engineer/Blacksmith so have always done a bit of machining. I’ve been in the oil industry working for nearly 15 years now and my work offshore as a Mechy I can spends days on the lathe\mill or go 2 weeks without using it, mostly turning shaft/bushes some threading and general repair work.
I have a workshop at home and do a bit of Engineering to keep my hand in, I have a an old Colchester triumph 2000 at the moment that I cleaned up and works away good. But I’m considering a bigger Lathe as I’ve had to turn away a couple of jobs due to not having enough swing or hollow spindle size.
I’ve even looking at Colchester Masstiff & Mascot’s as I’ve used them in the past but the Colchester’s seem to hold a higher value even for old abused looking ones, I’ve seen you can get a TOS lathe for a lot less money. Has anyone got any experience of them or could give me info on other brands of lathes around this size.
Cheers
Kev
Cheers
Kev
