Hello, I am hoping someone can help me to get my milling machine tracer attachment operational. When I bought the machine, it had all the hydraulic lines disconnected, but they were labeled as well as plugged to keep debris from entering the lines. I am looking for some insight on how to properly bleed the hydraulic lines for the tracer, and if there are any additional steps, tests or tips I should know about prior to using a previously disconnected tracer attachment. The mill is a Cincinnati Contourmaster with the 1C Acratrace setup. I recently found and purchased an original manual for this tracer but it does not discuss the bleeding of the lines or any initial start up procedures. If you don’t have knowledge of this exact mill, but have experience with the hydraulics on other tracer mills, I would appreciate any advice you may have.
Thanks in advance for the help.
Josh
Josh
