Using an arbor support on a large TOS horizontal boring mill for line boring
Page 1 of 2 12 LastLast
Results 1 to 20 of 32
    Mar 2006
    NW Pennsylvania
    39
    Default Using an arbor support on a large TOS horizontal boring mill for line boring
    My company builds very large mill equipment that utilizes large pin joints. The weldments weigh as much as 6500 lbs. For 40 years we clamped the weldment to the mill table (50" x 50") and then bored 4" to 6" holes thru multiple plates that may be 36" wide. There is an arbor support available but they never took the time to set it up. Did I mention that the material was A514? We use brazed carbide lathe tooling in a large bar. They extend the spindle as far out as needed then feed the part into the spindle. The spindle speed and feed must be extremely slow because the spindle is extended so far. I want to try using the arbor support but can't convince the shop to try it. Anyone have any thought on using an arbor support?
    May 2018
    30
    14
    Back when the earth was flat & the Buffalo were plenty....
    A shop I worked in used the outboard support when we “core drilled” 3”-4” dia holes through castings about 3-4 feet in length.
    So, yeah it will work.
    Apr 2004
    Modesto, CA USA
    6,883
    1149
    I can not imagine not using the arbor support for that deep a cut at that diameter. I am sure increased cutting speeds will more then pay back the time to set up the arbor support if you already own one. Why do they refuse to think the machine makers know at least as much as they do about their machines?
    I bet they do not use seatbelts since they know they will not help in a crash.
    Bil lD
    Jul 2009
    S.W. PA
    236
    62
    57
    My only though sir is that it is a pain in the ass to mic these bores with a supported bar in place.
    Bob.... not the cat.
    Oct 2005
    15,127
    Quote Originally Posted by CC View Post
    THIS is in "NW Pennsylvania" and I helped in the purchase and install.
    Old by any means, but it has the outboard support (the owners requirement for purchasing)
    Synchronized to the head, as well as several bars up to 4" dia.
    Also, the bars have toolbit holes every 12" or so.
    On this job with (2) bushings, the toolbits can be set in both places at the same cut dia.,
    and thereby increasing production.
    Attached Thumbnails Attached Thumbnails hpim0604.jpg   hpim0605.jpg   hpim0607.jpg
  6. Likes awake liked this post
    Oct 2005
    15,127
    Quote Originally Posted by Bobnotthecat View Post
    No it isn't if you make an adapter for you measuring tools.....
    Feb 2014
    NW PA
    11
    Quote Originally Posted by Bill D View Post
    Bil lD
    If the machine time, and possible rework doesn't cut into your profit margins too much over the last 40 years then it must be an acceptable practice for the bore tolerance. Sounds like change is hard in this company and CC has his work cut out for him.
  9. #8
    Oct 2011
    West-Central Illinois, USA
    1,239
    1999
    564
    If this is an older TOS W100A type he may have the spindle supports that clamp to the facing head (like 18-24”dia). In that case → HELL YES!
    They both clamp to the facing head, one clamps tight to the bar and could take the tool past the table center (this one limits spindle speed to 220ish RPM). They also had one with a bearing in the end that allowed spindle speeds to 800ish RPM with the facing head locked & not turning. They both look like traffic cones.
    If they can be talked into the live spindle (high speed) support, if it heats up fast then you’ll have to do some scraping on the support bearing to settle it down. BTDT...
    OTOH if it's the foot support & align bar setup then they work OK except it's a little weak cutting in the center of the table...
    Good luck,
    Matt
  10. #9
    Apr 2006
    Manchester, England
    8,257
    1201
    5231
    Are we talking about a spindle support housing that will allow you to extend the travelling spindle further out ? Or are we talking about using the outer steady bearing which allows you line bore ?
    Regards Tyrone.
  11. #10
    Mar 2006
    NW Pennsylvania
    39
    Talking about the outer arbor support.
    Update: It takes us quite a while to bore (1) 5" diameter hole for a distance of about 30".
    There are (5) plates that vary in thickness from 3" to 6" that need to be line-bored.
    The starter holes are about 1/2" diameter under the finish bore.
    Any thoughts on the amount of time it takes us to bore a hole?
  12. #11
    Jul 2009
    S.W. PA
    236
    62
    57
    Every TOS horizontal boring mill I've ever seen had a built in rotary table. If that's the case here, why couldn't you just turn the work around and line up on the previously bored holes, thus keeping your boring bars as short as possible.
    Bob....not the cat
  13. #12
    Nov 2017
    Kansas
    293
    68
    136
    If they couldn't see the light in 40 yrs you will probably not succeed in showing them. You might be better off buying your own hor bore and offer to do it for them. Base your price off their time.
  14. #13
    Mar 2005
    Northwest Indiana
    4,068
    716
    774
    I have run HBMs with the outboard support countless times. Never for bores that small. Usually 12" diameter plus and 48" length or more. Anything much smaller and you'll likely spend more time getting the bar in and out than the machining will take. What is the spindle diameter? How long are the bores taking you? Ideally with the setup you're describing I'd hit them from both sides on a turntable, holding bore centers inline with measuring spots cut in a setup at 90° to the bores. Shouldn't take long at all.
  15. Likes Tyrone Shoelaces liked this post
  16. #14
    Jul 2009
    S.W. PA
    236
    62
    57
    CC,Sir
    I have on occasion seen and used self aligning bearings mounted on plates with bushings sized to fit boring bars or the spindle itself to support the boring, either ahead of the bar or after. Moving from one bore to the next. Perhaps you could do this just on the heavy roughing cuts and finishing cuts sans bearings. These were held in place with clamps and/or tack welded in place.
    Bob....not the cat.
  17. #15
    Mar 2006
    NW Pennsylvania
    39
    Thanks for the reply.... I wish I had more experience machining this big stuff. My goal is to TRY and make the process better and get the job done in as little time as possible with the equipment we have. As far as time goes, what do you think approximate average time would be to open a 4.75" diameter burned hole up to 5.25" with a bore length of about 29" using a machine that is not "PERFECT"...lol. The actual cutting thickness is 19" of metal in the 29" bore length. The material is A514 and the starter holes are burn table torch cut so there is a hard crust on the first cut. Does "Shouldn't take long at all" mean an hour or a day per bore after everything is setup and bolted down? Any way you look at it, the machinist has a tough job...
    Would you please describe how you use "measuring spots"?
    Thanks for your help!
  18. #16
    Oct 2005
    15,127
    Simple process.
    Send the next job out, "NW Pennsylvania" has several capable shops.
    Shouldn't have to truck it more than 50 miles, and 6000 lbs is nothing.
    Then you have some numbers (even with profit figured in)
    Next job, tell inside shop to "equal the time, or this job is gone"
  19. #17
    Jul 2009
    S.W. PA
    236
    62
    57
    CC,
    Sir,
    How do you burn a 4 3/4" hole through 29" thick plate. You say that is the bore length. I'm confused.
  20. #18
    Mar 2006
    NW Pennsylvania
    39
    The weldment is made up of 2 to 3" thick plates welded down to a main base plate.
    Imagine a house with 6 parallel walls and the bore goes thru all of the walls and is parallel with the floor.
  21. #19
    Mar 2006
    NW Pennsylvania
    39
    The goal is to do the job in house. I'm just trying to become knowledgeable about the process so we can get er done efficiently as possible.
  22. #20
    Jul 2009
    S.W. PA
    236
    62
    57
    Cc
    Sir,
    So the spread is around 29". Makes a lot of difference! If I bid this for my shop I'd say 6 bores X 3 hrs/bore = 18 hrs plus time for de-burring, handling and setup/teardown time.
    I am not looking for work though.
    Bob....not the cat.
