kenscabs
Cast Iron
- Jan 24, 2009
- Sacramento
So I recently picked up a Wadkin BER2 spindle shaper. The only spindle that came with it was a 1". Doesn't seem to be a lot of parts for this shaper floating around in the US. Interesting the spindle is straight, no taper for locating. Tolerances are tight, spindle measures .9997 +-.0001 and the bore to the best of my abilities is 1.0002. I had to tap it out with the draw bar. I'd like a 3/4" spindle and a 1 1/4" I found a 1 1/4" in England but it'll probable be $500 to get it here which seems like a lot for a straight shaft. I recently made an idler shaft for an edge sander from 4140PH which went fine but reading on PM and metal sites ETD 150 might be the ticket. Seems straight forward to turn between centers to keep everything in line. Any thoughts?
