crossthread
Titanium
- Aug 5, 2004
- Richmond,VA,USA
Good morning. I have a project where I need to accurately track a rotating element in a paper converting machine. I see various offerings of flexible scales but I have no experience with them. My plan is to attach the scale to a 12 inch diameter column and track the rotational position of a cutter head. Have any of you used these flexible scales and if so are there any pitfalls that you know of? I can't quite figure out how to join the two ends without losing indexing at the joint. Nothing from my search explains how to make that joint. It may be better to use an encoder disc but there is no access to the top or bottom of the rotating element. I need to measure from the side if possible. My other option is to say to heck with it and let the plant electricians figure it out. That is an issue in itself. I walked in here and there are eight guys standing around and I swear they don't have a full set of teeth between them. Thanks very much.
