Hi all, new here and seeking help.
Let's assume that cost isn't an issue for a very hardcore enthusiast. There is a plan to create a machine shop that will be utilized part-time, working with steel and aluminium. About 20 hours per week plus perhaps a couple of hours of miscellaneous usage...
If we wanted to create a machine shop utilizing most of the basic tools - CNC, lathe, drill press, vertical/horizontal saw, vertical mill, compressor, welder, etc., along with heating and heavy computer usage...
And this shop is to be run by a massive array of solar panels and supercapacitors for energy storage. What amount of energy would need to be stored for roughly a week (20 hours of typical machine shop usage) of use?
It can be pretty ballpark with some extra energy added just in case.
We're planning on using 200 Watt-hour storage capacitors that are rated to run heavy electric transportation, figuring that this will be sufficient for the details above.
The only thing left is figuring out a ballpark estimate of how much energy storage is needed.
Any help would be appreciated - thanks!
Edit: Just realized how little those capacitors held. They discharge at over 700 KW though which is insane. Instead, we'll be using 13.5 KWh banks with 5 KW continuous discharge capability.
