UV activated adhesive
Results 1 to 16 of 16
    Sep 2013
    PA
    489
    234
    370
    Default UV activated adhesive
    I make a lot of vacuum fixtures to keep thin and delicate parts in spec while machining and have a part that I think would be best made using UV glue.
    Does anyone here have any experience using it as part of a set up?
    The part in question would be glued to a fixture to keep it supported then the part itself would be held in a soft jaw setup.
    Aug 2004
    Virginia
    2,233
    174
    806
    I have used the uv curing adhesive made by Dymax with some success however I was not overly impressed. It lacks the strength I was hoping for for one thing. The only thing I found useful was that you can hold something in position and then zap it.
  3. Likes yoke liked this post
    Sep 2013
    PA
    489
    234
    370
    How did you break the bond after machining? I can't really pry on the part without damaging it.
    Am I making it up but I recall hearing about an adhesive that is hardened with one light and loosened by another? Anyone hear of that or was it a fever dream I had?
    Jun 2008
    Bellingham, WA
    3,879
    929
    2003
    Unfortunately I have no personal experience with UV cring adhesives. However, Henkel, the manufacturesr of Loctite, has a ton of experience. I am confident a call to them would answer your questions as authoritatively as is possible.
    UV Adhesives/Light Cure Adhesives
    In the middle of the above page is a link to a general decision tree concerning their product and at the bottom is a phone number to call for techincal information. They have a good reputation for providing tech help.
    Denis
  6. Likes yoke, Archer120x liked this post
  7. #5
    Sep 2013
    PA
    489
    234
    370
    Quote Originally Posted by dgfoster View Post
    Denis
    This is a great resource. I'll give them a call.
  8. #6
    Nov 2010
    Virginia
    113
    132
    12
    Used it a bunch, but on stuff that it was ok to get hot, so we just put the whole thing in the furnace when we were done. Made a plywood curing box. Be careful - the UV lamps can give you a sunburn very quick!
  9. #7
    Mar 2017
    LATVIA
    270
    71
    144
    why the UV cure system? are parts or fixtures transparent so the UV can actually get to and activate the glue?
    what are the materials? wouldn't cyanoacrylate work better (if the fixture/part materials are compatible)? a little bit of heat to get it to release the part after machining and easy clean up as well
  10. #8
    Feb 2011
    Indiana
    23
    15
    13
    Call Tom @(219)671.1998 He is a Loctite/Henkel UV Adhesives Specialist and will tell you all about their products and advice if it is a good fit for your application.
  11. #9
    Nov 2014
    Florida
    3,201
    1427
    1505
    No exp with UV glues, but we make parts out of .002" brass shim that we use regular 3m type spray adhesive to hold. What we do is skim our 'fixture' plate so it is nice and flat, clean up with acetone/air, spray the adhesive on, wait a minute then attach the piece of shim and use a 1-1.25" pin to roll it flat and get it to glue down. Works good for our purposes. Keep in mind though we are using .006"-.010" endmills so there isn"t anything much of tool pressure.... A quick shot of acetone and a razor blade get the part off the plate.
  12. Likes Thunderjet liked this post
  13. #10
    Feb 2011
    Indiana
    23
    15
    13
    Btw, have you considered wax? We had a great success with it holding delicate glass parts during the machining operations requiring lots of coolant.
    3M adhesive is also good but it tends to get softened and partially dissolved by our coolant.
  14. #11
    Nov 2003
    Beaumont, TX, USA
    4,809
    165
    1450
    How about hot glue? Removable with heat.
  15. #12
    Dec 2012
    Se Ma USA
    1,434
    110
    810
    Your dentist uses UV cured fillings. I have a few. I had a few scratches in my granite counter top that I made to disappear with UV clear. 5 years ago and still cannot find them.
  16. #13
    Jan 2003
    Temple, Texas
    2,361
    15
    233
    Soft Solder is a good choice in some circumstances.....
  17. #14
    Sep 2012
    NW Iowa
    240
    130
    191
    Quote Originally Posted by Scruffy887 View Post
    I've got crowns that are held on with UV cured adhesive. I'm pretty sure there is a way to unglue them too as I've had some work done on a few of them and they were removed and replaced.
  18. #15
    May 2009
    Canandaigua, NY, USA
    2,783
    133
    1200
  19. #16
    Mar 2011
    Huron
    1,352
    1887
    845
    Don't forget about shellac resin, it's been used for millennia as a fixturing adhesive. And there's woods metal, it has a low enough melting temperature to be usable as long as you control the part temperature.
