Vascomax350 Maraging steel as a tail stock quill
Results 1 to 15 of 15
    Nov 2011
    Alberta
    480
    50
    118
    Default Vascomax350 Maraging steel as a tail stock quill
    I have a piece of this and was wondering if it would work as a tail stock quill material? What would be the pros and cons? Thanks in advance.
    Feb 2001
    Redwood City, CA USA
    4,938
    175
    882
    Maraging 350 should make a great TS quill, provided you have the tools to machine it and facility to age-harden it. You may be able to machine it close to final size, if not final size, and then age and not have it warp. You'll have to look up whether a size change is expected on the diameter after aging. If you have access to a cylindrical grinder, great. If not, you can lap the OD, but finishing the taper socket in the hardened state will be a problem without an internal grinder. The material is very expensive, but has really nice mechanical properties, and it takes on a nice oxide finish that is resistant to atmospheric corrosion. You are lucky to have it.
    Nov 2011
    Alberta
    480
    50
    118
    My plan is to machine it to +.010 inside and out the harden then send for grind. Not familiar with the age-hardening will have to do some home work on that.
    Thanks for the info.
    Sep 2010
    Oklahoma City, OK
    4,161
    718
    1757
    That's one hellaciously expensive material to use for a lathe quill, $750 for a 2" x 12" rod.
  5. Likes sfriedberg liked this post
    Oct 2005
    14,527
    Quote Originally Posted by Cole2534 View Post
    Yup, what machine is this for ?
    A 7 x 12 HF ?....
  7. Likes plastikdreams liked this post
  8. #6
    Jul 2006
    Hillsboro, New Hampshire
    7,169
    1675
    4927
    Is it the cobalt that makes it so costly, or just cause "they can"?
  9. #7
    May 2011
    New Jersey
    1,914
    173
    1036
    A 7 x 12 HF ?....
    Hey if you got it use it...right
    Sounds like it's good stuff but may be a bit overkill.
  10. #8
    Oct 2005
    14,527
    Quote Originally Posted by plastikdreams View Post
    Did someone say "Overkill" ?
    Men At Work - Overkill (Video Version) - YouTube
  11. #9
    Sep 2010
    Oklahoma City, OK
    4,161
    718
    1757
    Probably a lot of both.
  12. #10
    Mar 2005
    Kansas
    7,410
    424
    3393
    It would be a waste of expensive material. Vascomax's niche is where very high strength is needed, or high strength to weight. A tailstock needs neither.
    In a tailstock surface hardness is important to keep from scarring the taper. Rigidity is important, but the only practical means to increase rigidity is a larger diameter. Case hardened 1018 would do just as well as Vascomax, but I would probably use a pre hard and skip the heat treatment given the low value of the lathe.
  13. #11
    Nov 2011
    Alberta
    480
    50
    118
    So I will probably shelve the material and find a different piece of material. We have about 5 feet of 2.5 dia that has been sitting a shelf since the mid 60's so it will probably sit for another few decades... Not sure where the idea of the cheap lathe came from but it isn't a china machine. I found a piece of Ultimo 200 that will probably work. Thanks again for all the input.
  14. #12
    Oct 2002
    woodland wa clark
    953
    20
    I have cleaned a few tail stock quills and most of them machine like 1144
  15. #13
    Nov 2011
    Alberta
    480
    50
    118
    I have inspected quite a few tail stock quills from around the world, Hardinge, Smart and Brown, Standard Modern, Sheldon and a few from Europe and they all seem quite soft. Why wouldn't they harden them like a spindle?
  16. #14
    Feb 2004
    Baltimore, MD, USA
    4,000
    280
    575
    Its nice to be able to machine the end of the quill after reaming or if tooling needs clearance for some other reason.
  17. #15
    Jan 2005
    CANADA
    Saskatchewan
    10,187
    1382
    3658
    Quote Originally Posted by legoboy View Post
    If the tool slips in the taper, it still makes a mess, fully hardened or not. My pillar drill has a fully hard surfaced spindle socket and it's still got a gouge in it from something. It's just more of a bitch trying to clean it up when it is that hard. Be better to have something that a reamer will scrape effectively.
