I built a Vibratory Deburr machine from a 30 gallon plastic drum cut in half, and a 1/2 HP motor.
It actually works pretty good. I have 50 lbs of 3/4 dia abrasive cones, they jump and vibrate, and the parts tumble, so I'm happy with it.
I put 3-4 gallons of water in it to start, and some (probably too much) liquid laundry soap.
It smells great when it's running, just like fresh laundry. Over time, the liquid has changed from clear to white. It has run about 4 hours total and I emptied the drum today to make some changes
To my surprise there is about a 1/2 inch of fine white powder sludge on the bottom that is stuck together, and a lot of cones stuck in it.
It comes out with a putty knife, it's not hardened, it dissolves with water.
Is this normal with vibratory abrasive cones to produce sludge, or could this be from the laundry soap condensing and turning to glue.
Thanks, Racecar
Thanks, Racecar
