elysianbike
- Jul 23, 2019
Hey Folks,
I recently purchased a Victor 1640 — it was a ridiculous deal compared to what other 1640s seem to be selling for.
I'm new to using an engine lathe (prior experience with lathes was in a wood shop 10-12 years ago) so I'm trying to go about the initial set-up, cleaning, etc carefully (it powers up + runs fine. I've done a few small cuts on it so far).
I'm a bit unsure about a missing part of the lathe:
On the front next to the quick change lever there should be a button but it's been removed and the wires have been taped off.
In the manual it's listed as a Tip Engine Button.
Section 5-3 in the manual says: "For speed change easier, also adjusting the center for raw material when 4-jaws chuck used, in the lower portinn of feed gear box, there has a Tip engine button (8), push the button lightly, spindle running positive, and stopped while without applied the force on it." (that's verbatim)
I have no idea what this actually means — partially from being ignorant and partly from the poor translation. Could someone help me understand what this button does and if I should go ahead and replace it? As I said, the machine seems to run fine w/out it.
Cheers!
T
Cheers!
T
