Victor 1640 Question
Results 1 to 6 of 6
    Jul 2019
    Default Victor 1640 Question
    Hey Folks,
    I recently purchased a Victor 1640 — it was a ridiculous deal compared to what other 1640s seem to be selling for.
    I'm new to using an engine lathe (prior experience with lathes was in a wood shop 10-12 years ago) so I'm trying to go about the initial set-up, cleaning, etc carefully (it powers up + runs fine. I've done a few small cuts on it so far).
    I'm a bit unsure about a missing part of the lathe:
    On the front next to the quick change lever there should be a button but it's been removed and the wires have been taped off.
    In the manual it's listed as a Tip Engine Button.
    Section 5-3 in the manual says: "For speed change easier, also adjusting the center for raw material when 4-jaws chuck used, in the lower portinn of feed gear box, there has a Tip engine button (8), push the button lightly, spindle running positive, and stopped while without applied the force on it." (that's verbatim)
    I have no idea what this actually means — partially from being ignorant and partly from the poor translation. Could someone help me understand what this button does and if I should go ahead and replace it? As I said, the machine seems to run fine w/out it.
    Cheers!
    T
    Nov 2002
    St.Louis, Missouri, USA
    2,089
    125
    469
    It sound like a spindle jog button to me. For rotating the spindle slowly while centering a part or to help when shifting spindle speeds. When changing speeds if the gears aren’t lined up properly it helps to rotate the spindle.
  3. Likes eKretz liked this post
    Sep 2005
    Northern California
    861
    108
    I'm guessing this is what we would call "JOG" which is a momentary contact that lets you "bump-rotate" the spindle. Say you need to access chuck jaws for change out and so forth. Rather than putting gear train in neutral and rolling the chuck manually, you tap "JOG"
    Apr 2009
    Beaver County Alb. Canada
    1,879
    542
    924
    I have the same machine, my Spindle Jog Button works but never use it.
    Apr 2004
    Modesto, CA USA
    7,377
    1282
    Any push to connect, momentary contact, switch should work.
    Bil lD
    Jul 2019
    Thanks for the assistance ya'll. I'm super new to the forum but have already found a bunch of helpful threads, etc. I really appreciate your willingness to share info, etc.
    -T-
