I have a pretty broad/general question I am hoping to get some feedback on. How much force (in ft/lbs) is required to hold a billet of stock in a vise for machining?? Is there a calculation I can do for material type and material removal rates? More specifically, if I am trying to hold a 2" thick x 4" wide x 6" long piece of 6061 aluminum in a vise with "gripper jaws" (dovetail with serrations...) what could be an expected ft/lbs to hold said piece? Not serious hogging, more HS paths with moderate stock removal... the vise would be gripping on the 4" wide x 6" long (2" would be the height in this case).
1) the less area you are gripping the more the metal will crush or deform rather than take any more pressure. i get that often when gripping less than 0.125 depth on small parts maybe 1.0" long.
.125 x 40,000 = 5000 lbs, compression strength on various materials varies just saying over a certain point and it will leave marks
2) if item is not centered in vise or a block not put on left side to balance part on right side, this uneven vise pressure can easily cause one side to lift up when milling. holding force reduction hard to say could easily be less than 50% when not clamped in center of vise
3) a tall item in a vise has more leverage. if part is 1.0" wide and sticking up 6.0" out of vise and only held in vise 0.125" there is a more of a chance it will move in vise
4) dovetail, knurled surface jaws. if part is only partially sunk into part, further vibration can cause metal to deform more and vise clamping pressure to go down
5) part is 1" thick or high and held in vise 0.125" and measures 6x6" and is machined down to 0.200. as more metal is removed part will bend more more vise clamping pressure and pressure will go down. part humps up in center from vise clamping pressure, thus why before finish cuts vise is loosened and reclamped lightly
6) 1 hp = 33,000 ft lbs per minute so at 100 sfpm = 330 lbs
at 10 sfpm = 3300 lbs
......... had a metal shaper with 1/2 hp motor, if pulleys set to run slow that 1/2hp motor could easily push many 100's of lbs......... so slow sfpm = high forces
....... do not underestimate the slow flycutter, whack whack whack like hitting a item with a hammer and parts can easily start moving much easier than a end mill going 1000 rpm
