Vortex Cold Air system: anyone using?
Likes Likes:  0
Results 1 to 14 of 14
    Feb 2017
    484
    8
    150
    Default Vortex Cold Air system: anyone using?
    Anyone using the Vortex Cold Air systems, and for what, and has it been successful?
    May 2011
    New Jersey
    633
    13
    216
    I have a customer that loves it, but it sucks air like crazy. Need something like 15+ cfm just to run it. It does come out very cold. It is somewhat loud as well.
    Jan 2007
    Flushing/Flint, Michigan
    8,377
    437
    6890
    I've used them for dry machining of hardened (40s-50s) steel since basically forever.
    Not sure they are that much better than a regular air blast and they do work the air compressors very hard so money spent to run.
    They do help keep the part and cutter temp under control which helps with size control.
    I've tried them for grinding and found them here of no use at all.
    Grind I do wet since I'm setup for that. (strange, I machine all dry or min lube and then I grind all under very big flow flood)
    Seen some used for cabinet cooling. IMO, this is a terrible waste.
    There has been quite a few threads about these over the years here.
    Moving a lot of air on a milling cutter is always good to prevent re-cutting chips. If cold gun or compressor output temp is a question not usually separated.
    For sure a cold gun is better than nothing but maybe just an air nozzle without the big loss that comes out it's butt is just as good?
    I do use them but I'm not sold on them and wonder if I'm wasting money on making air.
    Bob
    Dec 2008
    New York
    10,235
    2657
    Quote Originally Posted by drcoelho View Post
    they blow cold air, kinda of noisy. if using minimum cutting oil it blow fumes away and cools part. my experience good to have one in shop if machine not made for flood coolant and using minimum cutting fluid/oil and need air to blow away smoke
    Oct 2005
    16,639
    I have one I wear on my belt....
    Dec 2013
    777
    239
    456
    I used one on a surface grinder taking off a few thousandths dry. We used to resharpen punch press tooling and tool life wasn't very good on the resharpened tooling. Tried out the Vortex cold air gun, it kept everything nice and cool and tool life definitely improved. But yes, they can eat up compressed air. Depending on what you are trying to accomplish, they also make the vortex tips that cut down on cfm usage and noise but still keep a strong blast of air where you need it, but without the extra cooling effect. Something like these:
    Air Nozzles-1201
    Dec 2008
    IL/WI border
    3,362
    1184
    1048
    A Little Blue Pill substitute?
    Jun 2009
    Michigan, USA
    2,322
    3320
    1800
    I used to use one a lot for dry grinding tooling that was mostly for stamping dies. A little bit noisy and they do use a lot of compressed air but our air compressor was 4,500 HP so no big deal. The hose and tip would get frost on them if I let it run for more than about ten minutes. Not nearly as good as flood coolant but still much better than just compressed air.
    Jun 2009
    Michigan, USA
    2,322
    3320
    1800
    Quote Originally Posted by MichaelP View Post
    That would be my guess too.
    Mar 2006
    Auburn CA
    435
    5
    39
    Well since your question was open ended about for what..... I'll be light on details as it was done on a classified project. It was used to keep electronics cool. But we did not waste air. We used nitrogen. It worked well.
  11. #11
    Oct 2005
    16,639
    Quote Originally Posted by Big B View Post
    Can't operate google can we ?
  12. #12
    Oct 2010
    Dewees Texas
    2,494
    28
    706
    Recently I used ours for machining soft urethane. I tried chilling the bar in dry ice and alcohol but could not get into the machine and press cycle start fast enough. I put the Vortex tube on lathe and gave the part a minute to ice up then press cycle start with the cold air continuing to chill the part. Made an impossible job easy.
  13. #13
    Aug 2015
    Illinois
    1,459
    1065
    631
    I had a vest connected to a vortex tube. It worked great except for the condensate running down my ass.
  14. #14
    Oct 2005
    16,639
    Quote Originally Posted by Illinoyance View Post
    Hence the belt mounted....sandblasters use them, pumps the breathing air in under the hood as well.
