Walkie Stacker as a lift table
Results 1 to 9 of 9
    Apr 2004
    Modesto, CA USA
    6,748
    1122
    Default Walkie Stacker as a lift table
    There is a used walkie stacker cheap near me. Could it be used as a lift table to get work up off the floor to a more comfortable working height. Sounds unsafe to me
    Jan 2011
    BFE Nevada/San Marcos Tx
    1,046
    915
    545
    Without a pic of said machine, and a pic of what you want to lift, its pretty hard to form an opinion.
    I've been struggling with how to lift heavy stuff in my shop, sadly "heavy" is now anything over 50lbs.....best idea so far is little jib cranes on machines and workbenches, might have to add an outrigger leg to benches?
    Feb 2017
    76
    6
    30
    All of our parts are stored in pallets. We use the walkie stacker to hold the pallet at a comfortable height while picking. Works great until some genius decides to pick exclusively from one side until the pallet flips off the side.
  4. Likes sfriedberg liked this post
    May 2008
    Minnesota
    679
    350
    227
    I find the continuously adjustable height of my forklift forks to make a perfect work platform. Plenty stout to clamp things to or even attaching manual tubing bender.
    Safety folks always say what happens if the line bursts or catastrophic hydraulic failure. I figure I am about 1000x more likely to hurt my back or body working at a bad height than I am to be crushed by the hydraulic failure.
  6. Likes Shaybuilder, steve45 liked this post
  7. #5
    Oct 2009
    Olympia, Wa
    608
    301
    172
    I have an electric pallet stacker and it makes a good work table, I just have a piece of 1" plywood I throw up on it. It is often easier to lower the pallet stacker down to the floor and load a heavy part rather than bring the part to the gantry, and lift it up on a cart. Mine runs on 2 standard deep cells and got it for free, its a raymond. The only problem I have had with it, if you load something too far forward the drive wheel cant get any traction.
  8. #6
    Oct 2005
    14,547
    Sure thing.
    If you don't mind using only 3 sides, stumbling around the column, and stubbing your toes on the protruding wheel arms.
    Go to harborfreight (take your coupon) and buy a "lift table"
    they make a 500 lb and a 1000 lb unit.
  9. Likes M.B. Naegle, ptsmith liked this post
  10. #7
    Feb 2011
    2,046
    1387
    881
    We've done it, but all of our lift trucks rock side to side which is an inconvenience. Don't forget to lower it while you're away. We've had stuff get damaged a couple times because a careless employee left a load in the air at the end of the day and came in the morning to find it came down on top of something. There's always the blame game of "but the hydraulics should'a held (etc.)" but regardless, if they had just lowered it nothing would have happened.
    The actual lift carts I've seen tend to be built on a scissor style design that tends to be more stable and less prone to creep.
  11. #8
    Feb 2018
    159
    20
    28
    Go to harborfreight (take your coupon) and buy a "lift table" they make a 500 lb and a 1000 lb unit.
    I did exactly that. The 1K lb model is much more solid than the 500 lb model. Got one for ~ $200 with a 25% off coupon. One of the best tool purchases I've ever made. Very old man, bad back friendly.
    It comes in handy for lots of things. Like mounting a motor on my lathe. No way I could done that by myself without the lift table. I use it for swapping the vise and rotary table on my mill as well.
  12. Likes digger doug liked this post
  13. #9
    Jan 2005
    CANADA
    Saskatchewan
    10,192
    1382
    3666
    Quote Originally Posted by Bill D View Post
    Should be able to add a safety chain at the back of the fork carriage to the top of the mast.
