Walter's Great L1 Spindle Nose Wrench - Page 2
Results 21 to 40 of 42
  1. #21
    Jul 2007
    Hampton, Virginia
    2,505
    202
    206
    Thanks John,
    Saved and printed it. Just have to do the scaling now. For the smaller wrenches I will have to use thinner stock. Does anyone know the thickness of the original L0 and L00 wrenches?
    Walter A
  2. #22
    Jul 2004
    Houston, TX USA
    31,949
    Wrench "groove" width, dimension "M" is 1/2" on both. Would seem 3/8" stock would be just right.
    John Oder
  3. #23
    Feb 2006
    Indiana
    13,767
    787
    4549
    My Clausing 5914 lathe has an L00 spindle. The nut is 4.875" OD and there are 7/16+" holes for a pin spanner, Armstrong no. 466. The wrench is 7/16" thick and has a 7/16" pin. So a flat hook spanner will not work on my lathe. The grooves on the nut are small and have sloping sides, just to give oily hands a purchase for turning the nut by hand when it is loose.
    Larry
  4. Likes camscan liked this post
  5. #24
    Jan 2006
    Angier, North Carolina
    2,623
    1135
    994
    The L00 on my Cinci Traytop uses a spanner like that shown in the pictures. (Interesting that your Clausing uses a pin spanner instead!) I wound up making my own spanner from 1/4" mild steel plate, and it has been more than adequate, though I should qualify that I am an occasional user, not using it every day. I would say 3/8" would be plenty thick -- that's what I would have made it out of had I had any on hand.
  6. #25
    Jan 2005
    Victoria, Texas, USA
    4,573
    3061
    1246
    The L-00 nut on my Sheldon lathe is 4-1/2" OD and has 3/8" wide slots about 3/32" deep. Yes, a 3/8" or even 1/2" thick wrench will work. Work up pricing and I'll buy one from you. Thanks, Ken S.
  7. #26
    Jan 2006
    Burbank, CA USA
    1,476
    64
    3/8" would be the best thickness for the L0 wrench to fit my 1949 LeBlond Regal 17. The LeBlond L0 nut is knurled on the outside, but with a smooth groove down the center that the wrench should fit into. The groove is about 7/16" wide. A 1/2" thick wrench wouldn't seat as well, and might damage the knurling.
    I've got a pivoting style single jaw wrench that was in the box of junk that came with the lathe. It works okay, but if you offer a better one for a reasonable price, I'll buy one.
  8. #27
    Feb 2006
    Indiana
    13,767
    787
    4549
    Speaking of spanner wrenches, I came across this adjustable one by Facom (probably French) on eBay just now. I have never seen this particular tool before, but I maybe could have used it if I had it. Too much money (around $71 with s&h) for a just in case tool, though.
    http://cgi.ebay.com/Facom-Adjustable...QQcmdZViewItem
    Larry
  9. #28
    Mar 2005
    Maine
    1,468
    9
    621
    Walter, I'll take a L-0 wrench for a Clausing-Colchester 13". I can send you my broken wrench. It's only the curved part plus about 2". The handle is broken off, but it will give you the dimensions. I cringed as I watched the guy I bought the lathe from bang on the stub with a hammer.
    If you're interested, PM me your address and I'll send it.
    Jeff
  10. #29
    Dec 2000
    Bremerton WA USA
    10,718
    41
    4428
    Hook spanners are easy to make. Hot forging is probably the simplest and the most elegant but a good hook spanner can be oxy-acetelene or plasma cut from plate, machined as a ring cut to a 150 degree arc and a hook and handle welded on, or any variant including water jat.
    Use mild steel. Ordinarily mild steel may be considered too soft for wrench duty but a spanner for a D1 series chuck ring has a low duty cycle. Mild steel it can be heat treated a bit to maybe 30 Rc on the surface. Finish the wrench, heat it red, quench endwise with a rapid stirring motion in ice cold water. It's not necessary to draw the temper but a while in a 400 degree kitchen oven would improve things metallurgical.
    For the record a D1 series ring needs only a sharp knock on the spanner to draw up the taper as tight as it needs to be. I use a 10" length of 3/4 x 1 1/2 flat bar for a spanner pursuader on my L-0 lathe chucks. Beating on a chuck spannder with lusky blows of a big hammer is abusive and illustrates to knowledgeable bystanders that the hammerer is either ignorant (curable) an idiot, (lamentable), or insensitive and ham handel (an incurable lifelong trait).
  11. #30
    Jul 2004
    Houston, TX USA
    31,949
    L1 Mr. Addy, not D1
    John Oder
  12. #31
    Sep 2004
    Grafton New Hampshire
    326
    49
    16
    Walter.....I would like one for a L0 if possible......Thank you very much....Dean
    http://www.neufellmachining.com
  13. #32
    Jun 2008
    TN
    1,714
    470
    371
    Default L00 wrench
    Walter,
    I'd like a wrench for my L00 Boxford.
    The nut is 4 5/8" diameter, 1" wide with 6 notches.
    The notches are full width of the nut, 1/2" across and 5/16" deep.
    Thicker material (thicker than the 3/8" I see mentioned in previous posts) might be best for mine and I'll happily pay extra.
    This will be a big improvement over the wood block and hammer I'm using now.
    Photo of spindle nut attached.
  14. #33
    Jul 2007
    Hampton, Virginia
    2,505
    202
    206
    Quote Originally Posted by Forrest Addy View Post
    Say what? I cut and clean the L1 wrench in 15 minutes. How the heck is Hot Forging the simplest method?
    I would have to see it. With 0.25 carbon and an initial Rockwell of B68 you would more than likely need to carburize first. Why not start with a better material and leave all the heat treating alone? The big wrenches won't fit in the kitchen oven anyway.
    Walter A.
  15. #34
    Jan 2005
    Houston
    6,800
    1165
    3810
    FWIW, here's the business end of the L1 wrench that came with my Colchester. It is made from 5/8" thick steel. The rest is a solid round bar about 3 feet long.
  16. #35
    Jul 2007
    Hampton, Virginia
    2,505
    202
    206
    I have some samples of the wrenches made and am now putting the costs together. When I do I'm re-starting the thread in the commerce section where it belongs.
    To everyone who contacted me I will email you with a price, weight and shipping cost. I have a couple of specials made like the thick L00 for Henry A's Boxford and the extended L00 for Ken. These are ready to go out once I give them prices.
    Here is a photo:
    Walter A
  17. #36
    Jan 2007
    Norfolk, UK
    21,183
    16560
    17233
    Quote Originally Posted by GregSY View Post
    Not to hijack the thread, but what's the timber - sorry lumber okay woodin stick in the pic?
  18. #37
    Jan 2005
    Houston
    6,800
    1165
    3810
    Limy -
    It is the Hickory from this thread:
    http://www.practicalmachinist.com/vb...=glue+pressure
  19. #38
    Jul 2020
    Walter makes a very good tool, everything you need nothing you don't at a great price, and quickly.
    Thanks Walter.
  20. #39
    Jul 2007
    Hampton, Virginia
    2,505
    202
    206
    Quote Originally Posted by D.Clark View Post
    Thanks Walter.
    Thanks for the note.
    If anyone in interested the for sale thread is here.
    https://www.practicalmachinist.com/v...panners-370450
    Update prices near the last post on page 2.
    Walter
  21. #40
    Sep 2016
    Missouri
    1,085
    890
    349
    I received my L2 spanner sent by Walter's daughter Barbara. Its a beautiful piece of work.
    I want to remove the chuck on my Pacemaker before moving it.
    The spanner wrench will make the job so much easier .and prevent the use of unethical tactics.
    5/8" plate. No flex in that handle
    I slathered some of that rust-oleum hammered paint and baked it at 190F for an hour. That is very durable paint when baked.on
    Its a wrench so it wont stay shiny but will hang on the wall behind the lathe.
    I just painted my new to me $300 D-675 Kurt vice. I think its about 25 years old but It still had some Cosmoline on it.
    Thank You Walter and Barbara.
    A test photo
