Warpage of 52100 after heat treat?
Likes Likes:  0
Results 1 to 8 of 8
    Mar 2014
    220
    72
    Default Warpage of 52100 after heat treat?
    I need to make a roller bearing as the old one is not available (made in 1929). The inner part is a shaft which I made out of 8620 and case hardened to RC 62 and ground and all done. It has no cage so don't need to make that. Rollers are standard 1/4" x 1/4" so don't need to make them either. The outer bearing race I am going to make out of 52100. The question I have is how much will this race warp when I quench it? The OD will be ground and the ID will be ground and honed.
    The outer race is 1-3/4" OD x 1-15/32" ID x 5/8" wide.
    So how big do I make it to compensate for it going out of round after heat treat and not having to grind off a ton of metal? Also, how bad does 52100 oxidize in the oven? Do I need to add a few thou to compensate for the scale I need to grind off? I have never worked with 52100 before.
    Nov 2014
    107
    14
    21
    should not move a lot i woudl turn oversized on all specs. as to decarb 1550 for 20 min would not be too bad but i woudl coat with some kind of protection (i use really thin clay coating). quench woudl be in AAA or other med.fast oil. i dont have that in the shop and use parks 50. post quench but before temper cryo can be done not sure how much you would gain doing that
    Feb 2010
    ch
    3,113
    256
    425
    are you heat treating yourself? maybe look up martempering temperature for the steel.
    Jun 2012
    Michigan
    5,793
    5481
    3699
    It's relatively stable, and since you don't need to carbeurize it, I'd only add .005" or less per side to compensate for heat treating.
    Apr 2018
    7,300
    3569
    Quote Originally Posted by Mtndew View Post
    ^ Second the motion, .010" total for grind in that size, and ask the heat treater to do it in a vacuum or put it in one of those envelopes.
    Mar 2006
    jacksonville,fl.
    1,455
    1401
    489
    I had to make a bunch of needle bearing races a while back out of 52100 tubing. 30mm x 34mm x20mm. I left .005" on the id and od. I had a local heat treater do the job and had no scale. Had about 10 pct that wouldn't clean up.
    Mar 2014
    220
    72
    OK, thanks for the replies. I will be doing the heat treat myself and also the grinding and honing. I have a modern fully programmable oven but it has no atmosphere control. So the parts gonna see oxygen when it's red hot unless I put it in SS foil. So it looks like I need to add .010" to the ID and OD. And it sounds like it won't go out of round when I quench it? If I screw it up, can always make another as I had to buy six feet of the 52100 even though I only need 5/8".
    Jul 2006
    Hillsboro, New Hampshire
    12,406
    2844
    8626
    This paper on decarburization: https://digitalcommons.lmu.edu/cgi/v...ntext=mech_fac
    indicates that 52100 decarbs to about .003" of depth, so leaving .010" for removal stock should prevent that risk. But I only took a quick glance at the numbers, it might be worth your while to do a more thorough reading.
