Water jet or Laser
Results 1 to 14 of 14
    Apr 2016
    Tennessee
    133
    110
    17
    Default Water jet or Laser
    Looking at getting some parts cut out of some steel plate, water jetted or laser cut. What machine would be more accurate and the average tolerance that can be held on each machine? Also the average hourly rate in the South East?
    Thanks!
    Aug 2012
    Gurnee ILL. USA
    430
    165
    109
    This is like any machine tool. If the programmer/operator is real good ( like ours is fantastic) our water jet parts are very good. We do not have a laser but I would think if the guy running it knows their stuff parts will be good from it too.
  3. Likes digger doug liked this post
    Oct 2005
    16,049
    Ask the Vendor !
    Duh
    Feb 2013
    Madison, WI
    1,042
    1143
    677
    Waterjet is going to be a better finish and you can cut thicker stock. Laser is going to be faster and cheaper. Tolerances are dependent on stock thickness.
    Michigan
    78
    48
    This is highly dependant on material, thickness, tolerance, part geometry, and the shop/operator of the machines.
    My experience with plain low carbon steel under 1/2" or so is its far cheaper and faster to use a laser. The surface finish is very good, and there is minimal processing after cutting needed to do much of anything to it. Once you get above that thickness, there are typically noticeable issues with the finish on the pierce, hole geometry and shape suffers.
    Waterjet is more expensive, but has outstanding cut quality on thicker metal. If they can tilt the stream to compensate for taper, even better. There is no HAZ, so that is superior for cutting things like air hardening tool steel and other thermally sensitive steels.
    Jan 2014
    GA, USA
    25
    6
    Quote Originally Posted by AARONT View Post
    He pretty much summed it all up. We cut a good bit of 1/4" steel on our laser and it comes off smooth on the sides.
    Apr 2016
    Tennessee
    133
    110
    17
    Thanks to the ones with useful information. I did forget to add the material will be 1/4 thick. This gives me a direction.
  9. #8
    Oct 2003
    East Peoria, IL, USA
    5,408
    352
    807
    why not plasma? 1/4" is right in the plasma range too. it's much cheaper.
  10. #9
    Apr 2016
    Tennessee
    133
    110
    17
    I would like a decent finish and diameter tolerance of +- .01
  11. #10
    Oct 2003
    5,408
    352
    807
    Quote Originally Posted by edge22 View Post
    a GOOD plasma shop might actually get you there on 1/4" I've been shocked how good plasma can be. also how bad, depending on machine and operator.
    Plasma, waterjet and laser cutting systems from Hypertherm
    ......High-tolerance plasma uses a small nozzle orifice and intense gas swirl to constrict the arc. The result is an energy-dense arc with a very narrow kerf that can cut intricate details and very small holes. Conventional plasma systems can cut within 0.76 mm (.030") accuracy and produce cuts with 3–5° of bevel, sometimes as little as 1°. High tolerance systems can cut with 0.25 mm (0.010") accuracy and 0–3° of bevel. They can accurately cut holes as small as 4.76 mm (3/16").
  12. #11
    Nov 2010
    Tustin, CA
    396
    235
    119
    1/4" steel on laser all day long. If it needs welding (mainly tig) it will need to be dressed a little first. Most shops will probably have an hour or half hour minimum and maybe a setup fee. Will definitely be cheaper than a waterjet. Depending on parts, could probably do on a plasma as well.
  13. #12
    Jun 2015
    CANADA
    British Columbia
    1,191
    263
    620
    1/4" steel cuts fast and nicely on a waterjet. Inexpensive too. 0.010 accuracy is not a problem.
  14. #13
    May 2010
    Cambridge, MA
    1,652
    71
    946
    When I post stuff like this, my post gets banished to the Fabrication forum, but it is fine for everybody else to post welding and laser questions to the main forum. That's what I get for being a nudge.
  15. #14
    Jan 2009
    "Stuck in Lodi", Ca
    3,084
    1850
    1627
    Quote Originally Posted by jscpm View Post
    LOL - That's cause we don't like your avatar....
