I have a project where I need an internal gear and external gear cut out to make a drive coupler to match an engine to a transmission on a wheel loader.The internal gear is 12 1/4" major diameter with 72 teeth that are straight cut like a giant spline and the outer gear is about 17" diameter. The old coupler is 1" thick to engage the male gear.
What thickness of aluminum can a waterjet cut accurately and with some economy?
I could get by with 1 inch thick but would prefer 2 or 3 inch thick.
The way its done now is the internal gear is cut right into the engine flywheel and the starter ring gear is also used to scavange the oil out of the bellhousing and lift it up to a gravity drain back to the transmission sump. I want to put in a different engine that needs a housing adapter to mate the two. The aluminum drive adapter needs to be bolted to the new engine flywheel with appropriate spacer and piloting. This is a 100 HP diesel in a 18000 pound loader.
