I have a Harrison "Universal" milling machine. where "Universal" means that there are both a horizontal spindle, a pivoting vertical spindle and a swinging table.
The swinging table means that the machine can easily be set up for hobbing gears with spiral gear hobs.
Each hob has a lead angle engraved on it that tells me how far the table needs to be swung.
But the angles are typically something like 1°45' and the graduations on my table are every 1 degree and are fairly hard to see.
So I had the idea of using a micrometer head to dial in the angle. For small angles a 1mm micrometer at a distance of 57.29mm from the pivot moves the table 1 degree for every 1mm travel. ( 57.29 is calculated from 1/tan(1) ). An imperial micrometer head could be used at a distance of 5.729" from the pivot. Then it would, of course, be 1 degree for every 0.1" marking on the micrometer.
The problem is that this ceases to be accurate as the angles increase.
So I had the idea of having the micrometer bear on a specially shaped ramp that to correct for the disparity as the table swings:
The construction for the shape of the cam is shown below. It will be a different shape for every machine, as the distance from pivot to the micrometer face affects the profile.
The 0 degree line is constructed to put the end of the ramp in the right place for the other part dimensions. Then a similar construction is made at 5 degrres, and with a 5mm shorter construction line. This is repeated for a few angles.
The points can then be joined with a spline, and a CNC machine makes making the special shape fairly easy.
