timbo917
- Aug 7, 2011
- belgium/mechelen
Hello,
I am rebuilding a vintage two stage wayne air compressor pump.
I have already placed new roller bearings,had the crankshaft reground with new bearings
and the cylinders honed. Now when putting it back together i noticed a crack in the second stage piston.
I am not having any luck in finding an other piston,new or used. Having spend already a large sum of money I woold
like to have a go in machining a home made piston.
The original was made from cast iron. Can I make a new one from aluminium? Or should I use steel? Won't steel be to hard and
wear out the cylinder. Anny advise welcome.
regards
Tim
regards
Tim
