Ways to enhance life of " Circular Thread Roll"
Results 1 to 13 of 13
    Jan 2019
    INDIA
    10
    Default Ways to enhance life of " Circular Thread Roll"
    We are the manufacturer of "Circular Thread Rolling die" but nowadays we are facing the problem regarding the life of Thread Rolling Die as compare to other major competitors from other countries.
    We tried each and every possible thing to match the life of Thread Roll with them but we didn't succeed in this.
    ---- We are doing vacuum Heat Treatments.
    -----We are performing Nitriding and cryogenic treatment.
    -----We are performing the surface treatment or surface coating.
    -----Also done Raw Metal analysis which is providing long life.
    .. we want to know that is there is anything missing during the grinding process or something else.
    Oct 2005
    18,182
    Yes there is....But I get paid for that information.
  3. Likes PARBHAKAR YADAV liked this post
    Jan 2019
    INDIA
    10
    Okay No, Problem we are ready for that, What will be your charges and what if it doesn't work as expected ??
    Please reply I'm waiting for your answer. Or Contact me on +91-9958379326 Parbhakar Yadav
    Jan 2019
    INDIA
    10
    @ Mr. Digger Doug, It's okay No, Problem we are ready for that, What will be your charges and what if it doesn't work as expected ??
    May 2014
    Greece
    20
    10
    5
    What material you are using ?
    Jan 2007
    Norfolk, UK
    20,061
    15463
    15809
    ''Ways to enhance life of " Circular Thread Roll"
    Easy, Get it made in USA, UK, Germany, Sweden or Switzerland
  8. Likes camscan, Illinoyance, crazygoat liked this post
  9. #7
    Jan 2019
    INDIA
    10
    Right now using D2, HSS M2 and some other special grade between D2 and HSS M2.
  10. #8
    Sep 2006
    SW Wisconsin
    586
    58
    159
    Quote Originally Posted by PARBHAKAR YADAV View Post
    I make my own from D2. They do not last as long as M2 but I can do specials in house quick turn around that way. The biggest increase in longevity came from changing rolling lube.
    Ed.
  11. #9
    May 2017
    FINLAND
    2,188
    600
    1007
    Tough crowd here, either its too much hobby grade question or bizniz secrets.
    What we have left is Viagra and boats
  12. Likes SAG 180, dalmatiangirl61, gusmadison liked this post
  13. #10
    Jun 2015
    Florida
    38
    7
    Parbhakar,
    You may want to review the following links that give detailed information on thread rolling issues. I am retired now, but the mutually owned firms I worked for ran in excess of 80 multiple spindle screw machines, primarily Acmes and Davenport. All of our thread rolling operations were performed from cross-slides. We used Reed, Landis, and Winter thread rolling attachments. We rolled steel, aluminum, brass and 416 stainless. Our coolant was Mobil Omicron tri-purpose petroleum cutting oil. The lubricity in petroleum oil is better than water soluble coolants (at least at the time I was working).
    We traced the biggest problem with thread roll life to oversize blank diameter. Also, no dwell should be allowed when thread rolling. Get on & off the part as quickly as possible.
    https://www.pmpa.org/docs/default-so...6.pdf?sfvrsn=0
    https://web.wpi.edu/Pubs/E-project/A...Massey-MQP.pdf
  14. #11
    Jan 2019
    INDIA
    10
    Thank you very much sir for your valuable inputs we have gone all through this but didn't got any satisfactory results.
  15. #12
    Jan 2019
    INDIA
    10
    Can we perform some type of Buffing or Polishing on thread roll after profile generation to remove microcracks or to make surface more smooth will it enhance the life of roll or not ?
  16. #13
    Mar 2007
    On Elk Mountain, West Virginia, USA
    2,136
    951
    745
    It would help to know how your rolls are failing.
    If by fatigue and bits crumbling off, I would look at the quality of the steel you are buying. Uniformity of alloy distribution, and microcleanliness. Vacuum-arc remelting is one technique used to make cleaner steel.
    Then at your heat-treatment. Wrong temperatures or too long or too short time at temp can make a big difference to fatigue properties, even if hardness seems OK.
    Then at your grinding conditions. If your grit is dull or you are pushing too hard you may be locally overheating the surface and either lowering hardness or making microcracks. There is a fellow who seems to know his stuff that does consulting about grinding problems named Dr. Jeffrey Badger ("The Ginding Doc")
  17. Likes Philabuster, Milland liked this post
