Weak magnets in cylindrical square- Re-energize, or replace?
Results 1 to 15 of 15
    Apr 2005
    New York
    124
    39
    19
    Default Weak magnets in cylindrical square- Re-energize, or replace?
    This cylindrical square has weak magnets, barely enough to hold it in place.
    Can I re-charge them, or replace them?
    Thanks.
    Attached Thumbnails Attached Thumbnails 20200513_101623.jpg   20200513_101542.jpg
    Jul 2005
    Cottage Grove, MN 55016
    7,861
    4203
    4674
    You should contact these guys as they make them new. I see they have a repair dept that could possible sell you new magnets. Those 3 holes probably are there to press out the old magnets. The square looks like it needs a reconditioning, so maybe you can send it back to them.
    1-888-647-8665
    E-mail: [email protected]
    Apr 2005
    New York
    124
    39
    19
    Thanks for your reply Richard... They make fantastic products.. But I cant justify their cost for this piece.
    Mar 2005
    Kansas
    7,894
    486
    3756
    Knock the old magnets out and buy appropriately sized new neodymium magnets. Study the old magnets to see how they were made. The outer steel shell makes each magnet into a horseshoe magnet, bringing the other pole around to the face. The brass is just a separator. Get a couple of sizes, neodymium magnets are so much stronger than the originals that similar sized magnets may make it nearly unremoveable. You won't be able to grind the face of the magnets, so make sure you recess them at least .0005".
  5. Likes BuffDan, Richard King liked this post
    Apr 2005
    New York
    124
    39
    19
    Quote Originally Posted by gbent View Post
    Thanks for the input... The magnets have 2 brass shells and 2 steel for the magnet.. I'll have to get one out, hopefully intact..
    Not sure if I need to replace with magnet that has outer brass shell, or just the inner one..
    Mar 2005
    Kansas
    7,894
    486
    3756
    You have to make the brass shells. The outer is to keep from shorting that pole to the cylinder square. This gives better pull, and keeps the magnetic poles in a small area.
    Jun 2013
    Buffalo NY USA
    504
    328
    265
    I would be tempted to try and just knock out the magnets themselves first. Just the innermost part. Then shop around for some fresh ones. These guys are good, I've bought from them before: Neodymium Magnets For Sale - Rare Earth & Top Grade Neodymium Magnets now at CMS Magnetics
    FWIW (not much) I spent the winter lapping in a cylinder square for myself mostly with diamond plates. I started with an NOS piston pin. Ended up with +- .0001 over 5 inches, after about 2 weeks. Total cost less than $30 plus a lot of time.
  9. #8
    Aug 2006
    New Zealand
    1,303
    78
    277
    Hi
    You don't need to use brass. It only acts as a magnetic insulator. You could use expoxy glue (not JB weld. It contains metal) if the magnets are wedged away from the steel. You could glue in loose fitting brass sleeves. Glue avoids the need for precision fits.
    Dazz
  10. #9
    Nov 2014
    Florida
    4,511
    1730
    2161
    Do you know the square is 'good'? It doesn't look like it is in good shape from the pictures..
    Cylindrical Square | 57-020-263 | Travers Tool Co., Inc.
    Maybe just buy a new one...?
  11. #10
    Sep 2006
    Stillwater, Oklahoma
    1,481
    110
    812
    And put one huge effing magnet in it??
  12. #11
    Apr 2005
    New York
    124
    39
    19
    I haven't used it because the magnets don''t hold it in place very well.. I have cleaned it and painted since the attached photo.. I view this as a project, learning, etc. I believe it can be a useful reference for my shop.. And I like challenges. I haven't bothered with lapping yet as I want to replace the magnets first..
    Thanks for the inputs guys.
  13. #12
    Sep 2006
    1,481
    110
    812
    I have no particular advice on magnet replacement, but refurbishing as a square should be doable. Lap or hone the cylinder and it can be tested for size and straightness. Then check squareness and lap the base as needed. You should be able to get it as good as the limits of your measuring equipment.
  14. #13
    Apr 2005
    New York
    124
    39
    19
    The magnets popped right out, they were a press fit.
    They sure are weak..
    I ordered some neodymium 1/2x1/8 magnets.. They will fit inside the inner brass shields. I will probably have to dust the bores in the brass..
    So a 1/2x1/8 Neodymium rates at 5# pull.. I didnt need them that strong, but I'd have to get some really thin ones to lower that.
  15. #14
    Mar 2006
    jacksonville,fl.
    1,277
    1126
    428
    To bad they didn't make the base so you could turn the pull off & on.I refurbed a cheap mag vee block with rare earth magnets.I think I ended up with three 50lb mags.Very impressive!
    Another advantage, rare earth mags don't need a keeper and will last a long time.
    I found mine on E-Bay.The low power ones you want are pretty cheap.
  16. #15
    Feb 2010
    ch
    2,490
    215
    328
    Quote Originally Posted by BuffDan View Post
    just space them deeper from the surface.
  17. Likes JST liked this post
