What is the angle of BT40 taper?
Results 1 to 11 of 11
    cape Town, South Africa
    Default What is the angle of BT40 taper?
    All the references I find list the BT40 taper as 3.5" in a foot = 7 in 24.
    The diagrams I have seen all give the half taper angle as 8° 17' 50"
    Here is my confusion. 8° 17' 50" = 8.297222°
    Calculating the taper angle by trigenometry it is ArcTangent of 7/24. That is 16.260205°. Halve that for the half angle gives 8.130102°. That is different to the stated angle.
    Where am I making a mistake?
    What is the actual angle?
    I tried 8.297° on my machine & it does not seem to match my spindle.
    Dec 2000
    Bremerton WA USA
    10,697
    41
    4278
    Taper setting angles are an old machine shop trap.
    You gotta work conical tapers on the half angle because they are bodies of symmetry and revolution that is, generated from an axis. Half the tangent of the included angle is not the same as the tangent of the half angle. The half angle is what you have to set the taper attachment, compound, grinder platen, etc. Same when you set the bench center up with a sine bar for inspecting the taper angle.
    The half angle for a 7/24 taper is 8.2971 degrees or 8 degrees 17 min 50 sec and you can take that to the bank.
    If you're having trouble picking up an existing taper it isn't likely to be the result of competent calculation. Your tool height or indicator contact absolutely positively HAS to be in the plane of the spindle axis lying parallel to the tool path. 1/32 high or low and the spindle won't blue to the gage. Ideally the spindle mouth should be +.0000/-0.0002 with the gage. You got a gage?
    Then again it is possible some blithering dufus re-ground the spindle wrong and you get to deal with it now.
    Good luck.
  3. Likes Pali, digger doug liked this post
    Sep 2005
    Oakland, CA
    2,530
    323
    685
    Directly from ASA B5.10 Machine Taper Standard- the taper is 3.5in/ft. Also from the standard- 16 deg,35 min,39.4 seconds.
    Initially I made the same mistake as you did- I think. You have to calculate the tangent form the ½ angle- not the inverse tangent of 3.5/12.
    Lay out the taper on a piece of paper- the 3.5/12 is not a right angle, and that's where you get into trouble using the arc tan directly.
    Take the arc tan of 1.75/12 and then work it backward- The actual angle is 16 deg,35 minutes and 39.443 minutes.
    Also your half angle was not exact- its 8 deg,17minutes 49.72 miinutes.
  5. Likes michiganbuck, rob256 liked this post
  6. #4
    Sep 2005
    Oakland, CA
    2,530
    323
    685
    Forrest beat me to it while i was scraching my head figuring out where you went wrong. The clue to me was when I calculated the arc tan of the 3.5/12, the result did not match the deg,min.sec value in the standard.
    Dan
  7. #5
    May 2003
    Iowa
    10,492
    3616
    4274
    Steep taper holders all have the same angle 3.5000" / foot. NMTB, CAT, BT, and ISO all use that taper. Don't know about any of your "diagrams".
    JR
  8. #6
    Jun 2012
    Michigan
    10,197
    3459
    3646
    And...
    The taper you are trying to mate may not be a perfect taper so you may have to measure and then fit.
    To find the existing taper you can set an indicator inside and at center line of the spindle taper and set to zero. Move out exactly an inch so the indicator point is off and above the wider area of the taper. Raise the spindle or lower the axis holding the indicator to make indicator zero with measuring exactly the amount of travel.
    With knowing taper per inch you can manufacture what ever you wish to use in the spindle.
    Grind or turn the taper with leaving a little stock to blue the fit to exact finish.
    Certainly you can do the same in millimeters.
    Buck
  9. #7
    Dec 2000
    Bremerton WA USA
    10,697
    41
    4278
    Quote Originally Posted by michiganbuck View Post
    And...
    Buck
    I got a tube of metric blue for - um - $200 if you need it. Honest, I'm selling it at cost. Metric blue is almost impossible to find.
  10. Likes xdmp22, JRIowa, digger doug liked this post
  11. #8
    Many thanks. I get it now. Pathetic in retrospect.
  12. #9
    Dec 2000
    Bremerton WA USA
    10,697
    41
    4278
    Quote Originally Posted by tok-tokkie View Post
    You are not alone..
    If ever i get too arogant, complaiscent, and self important I inevitably recall humiliating events I brought on myself working the machinist trade. A trade where there is no end to the delusion, folly, and plain bad luck lurking behind every simple-seeming job. Suitably humbled I continue, sobered, humbled, clear eyed - until the next time.
  13. Likes Pali, stephen thomas, wheels17 liked this post
  14. #10
    Nov 2014
    NETHERLANDS
    >> atand(3.5/24)
    ans =
    8.2971
    >> atand(7/24)/2
    ans =
    8.1301
  15. #11
    Oct 2010
    Oregon
    5,150
    4442
    1873
    For what it's worth, this is a very common error. So you are in good company. The downside is that the error is so common, we can recognize exactly the mistake in the work you didn't show.
