What is the bending strength of 2" OD 304L tube; .065 & .120 wall? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21
    Feb 2007
    St. George, Utah
    906
    455
    602
    . . .and Gordon has to keep his remaining neurons in good shape.
    Ha! You noticed the decline, eh? I told my wife that any day now she'd not be the only one to see it!
  2. Likes Milland liked this post
  3. #22
    Sep 2014
    Georgia
    349
    259
    128
    Think about 2" x 4" x .12" rectangular, stainless-steel bars. 20' long supported not at the ends, but moved in to give a good balance between sag and yield avoidance. The image shown below would (I think) sag about .56" in the middle with a 600 pound load shifted completely to one side and about .43" at the start/finish bar shifted to one side.
  4. #23
    Feb 2007
    St. George, Utah
    906
    455
    602
    Thanks, David.
    Rectangular SS tube like that is too expensive and for this installation, too heavy. I intend to inset the supports like your drawing, the distance will be determined by ultra precise and complex testing: I'm going to lay two tubes across a couple of cement blocks and have the guy bounce on 'em in the middle. I'll move the blocks in until I get an acceptable amount of deflection.
  5. #24
    Langley, B.C.
    1,702
    352
    995
    Quote Originally Posted by Gordon Heaton View Post
    ..I intend to inset the supports like your drawing, the distance will be determined by ultra precise and complex testing: I'm going to lay two tubes across a couple of cement blocks and have the guy bounce on 'em in the middle. I'll move the blocks in until I get an acceptable amount of deflection...
    Sounds about right. This ain't rocket science. If you move the legs in from the ends a bit I'm sure the
    2" tube will be adequate.
    And a little hint: When you attach the legs angle them out a bit so they're wider at the bottom (at least a
    foot each side). This will make the bars more stable and it will also allow a little more "swing" room between
    them so when the boys are playin' they'll be less likely to swing into the legs...
  6. Likes Gordon Heaton liked this post
  7. #25
    Aug 2012
    California, Central Coast
    3,750
    2195
    1478
    Also when the legs are welded on they will help reduce sag, saging on the monkey bars will have to bend the legs.
  8. Likes Gordon Heaton liked this post
