What is the best method to measure this hole
Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Feb 2012
    The warm desert of Phoenix Arizona
    1,438
    325
    503
    Default What is the best method to measure this hole
    How do you measure the hole with out removing the bar?image_20190808_142205_1565299393557.jpg
    I'm asking for a buddy
    Thanks Ron
    Feb 2001
    Redwood City, CA USA
    4,938
    175
    882
    Measure the bar and add the telescoping gauge readings to each side of the bar. Not great, but better than eyeball. If the bar setup is any good, you should be able to withdraw the bar and measure and put the bar back. Depending on the drive and bushing setups, you might not get back on the exact same centerline, but the size will stay the same if you don't disturb the cutter. Hopefully the cutter increment for the next cut is bigger than the centerline shift from putting the bushings back if you had to move the bushings. DTI sweep to the rescue on that issue.
    Jun 2012
    Idaho
    3,124
    1722
    2040
    make a series of plug gages with relief for bar and cutter
    how tight of tolerances ?
    Jan 2007
    Mountain Home AR.
    115
    9
    68
    It looks like there is enough room to use an internal spring caliper and transfer to a micrometer. Old school but should be able to get well within earth moving equipment tolerances. Takes some practice. (It looks like a earthmoving part)
    Jan 2014
    Temecula, Ca
    2,736
    1242
    3556
    Portable CMM, or a tape measure.
  6. Likes Bobw liked this post
    Mar 2005
    Kansas
    7,410
    424
    3393
    Carefully.
    Line boring manufacturers have complete lines of measuring equipment they sell with their machines. York and Climax are the better manufacturers. Have your buddy look at some of their youtube stuff for measuring equipment.
    Some of the methods I have used include spring calipers, telescope gages in tool holes in the bar, measuring the gap between the bar and bore (be careful of bar runout), and fitting a near size tapered hollow pin on the bar before assembly. I have also used a special bore gage that clears the bar. No one method works all the time, so the more methods the better.
    Feb 2005
    9,018
    13662
    10662
    Quote Originally Posted by Larry Dickman View Post
    But is it really one of "Those" jobs...
    It obviously looks like its on some tractor that is beat to hell..
    I'd make a GO gage, with a few steps. Maybe .005, .010, and 20 under..
    Then hog out the guts so it will fit around the boring bar..
    It doesn't look like it will ever have to fly, so as long as the bearing
    stays where it is supposed to and does what its supposed to, who cares..
    This is a "Make it Work" job.. Not a "To Print" job..
  9. Likes sfriedberg, jrmach liked this post
  10. #8
    Feb 2004
    peekskill, NY
    24,214
    4411
    Quote Originally Posted by howieranger View Post
    +1
    With some practice you can do +/- 0.001 with this. Joe M would say, 0.001 TIR!
  11. #9
    Virginia
    26,033
    7561
    8213
    1) Direct measure: 24", 36" or 42" vernier caliper to get long, stiff jaws. Pair of bearing balls at the tips so I can work at an angle. Outside Mic to confirm. Multiple readings off marked locations. Check for error and variation.
    2) Indirect measure: Flexbar Indi-Cal with DI mounted. Measure left and right bar to wall, more than one place off Sharpie-marked locations. Outside mic the bar, same set of locations. Do the addition, Check for error and variation.
    If I did not already have the verniers and a pair of Indi-Cals, then:
    Attach outward pins to an OD spring caliper if my ID one won't clear the bar, 'coz it looks as if it may not, and I no longer have but one or two sizes.
    ELSE
    Fab a fixture that can transfer stable measurement to an existing mic.
  12. #10
    Mar 2013
    Danville Virginia
    118
    37
    These snap gages can be used in an empty hole in the bar. One end is spring loaded so you when you release it, both ends get pushed against the bore. They are good to a half thou.
  13. Likes Grinder74 liked this post
  14. #11
    Aug 2005
    Tucson AZ
    6,276
    9368
    2939
    Quote Originally Posted by slowmotion View Post
    Learn what a snap gage is:
    L
  15. #12
    Virginia
    26,033
    7561
    8213
    "Telescoping gages", you mean. Asymmetrical ones in this case, is all.
  16. #13
    Dec 2015
    Connecticut
    770
    22
    236
    How is a telescoping gauge going to work with the boring bar in the way?
    Edit: unless you mean like mentioned above. Measure gap on both sides of bar and add bar diameter. Make potential for 3x any inaccuracies
  17. Likes James H Clark liked this post
  18. #14
    Apr 2004
    Modesto, CA USA
    6,736
    1117
    Internal calipers and a micrometer.
    Bill D
  19. #15
    Virginia
    26,033
    7561
    8213
    Quote Originally Posted by ripperj View Post
    Poster of it mentioned operating it through an existing hole in the boring bar. Balanced (looking) types can sometimes do that, too.
    My approach, and those of most others, does not expect handy holes, nor need such.
    "Stacking" erorr is wot it is.
    One counter to it is tedious patience, multiple readings taken and reviewed such that even marginal metrology (story of my life, etc.) serves.
    Owning two Indi-Cals and a dozen or so DI, the DI substitutes for dodgy repeatability of "feel". Ve gang too soon Elt, und too late rich mit stoff.
    Care in use and multiple test points are still required, but they take less time. If the bar were more easily asided and restored, I'd use an ignorant bore gage - faster-yet.
    But if the bar could...etc. so would the OP have done, yah!
  20. #16
    Jan 2014
    Chicago
    150
    41
    53
    Another method would be to use a Pi tape.
    Sent from my SM-G930P using Tapatalk
  21. Likes wheels17 liked this post
  22. #17
    Mar 2005
    Kansas
    7,410
    424
    3393
    Quote Originally Posted by Silent_Man View Post
    If you have ever done this, please explain. How do you push the Pi tape in the hole and get it squared up, and still read the markings?
  23. Likes assface421 liked this post
  24. #18
    Dec 2002
    Benicia California USA
    7,992
    1778
    2351
    Well the OP question was "best"...
    If i could not pull the bar (should repeat)
    I would go with this gauge.....Part of the kit for my "BC4 Berco" line boring machine.
    Adjustable for different sized bores. Set size using ring gauge or micrometer.
    Has two centering points to center in the bore and one moving finger that is connected to the dial gauge....
    Opening clears the bar fingers read the bore...
    Cheers Ross
  25. Likes tdmidget, Trueturning liked this post
  26. #19
    Jan 2017
    Oregon
    2,453
    441
    1743
    I like that Berco gage.
    These work good too.
    Internal Caliper Gage | 57-015-072 | Travers Tool Co., Inc.
  27. Likes Bluejeep liked this post
  28. #20
    May 2010
    DENMARK
    3,154
    4007
    12665
    Quote Originally Posted by lazz View Post
    Thanks Ron
    Depends on the tolerance or how accurately you want to measure.
