What is the best method to measure this hole - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21
    May 2011
    southern in.
    1,431
    1915
    373
    I used to have a job that would come in occasionally that was similar. I cut the center part of an old Ford brake drum and used the center hole to clear the shaft. It was roughly shaped in a crescent shape. I drilled and tapped for small set screws on each end. polished a radius on the ends of set screws. Used one of the lug bolt holes to provide a handle. Works great, took about a 1/2 hr to make. Used it like an inside mike, then checked the dia. with an outside mike.
    JH
  2. Likes Trueturning liked this post
  3. #22
    Feb 2012
    The warm desert of Phoenix Arizona
    1,439
    325
    503
    Thanks we have several option to try and compare results...
  4. #23
    Aug 2019
    Ohio
    8
    6
    8
    https://www.mscdirect.com/browse/tnp...QaAqf0EALw_wcB
    Sent from my SM-T378V using Tapatalk
  5. #24
    Aug 2015
    Illinois
    1,348
    971
    576
    An asymmetrical telescoping gauge like Slowmotion showed might work. Lock it collapsed. Stick it through one of the open holes in the bar. Feed it into the hole. Unlock the plunger and re-lock it. Back the bar out of the hole and mike the gauge.
  6. #25
    Jan 2014
    Chicago
    150
    41
    53
    Quote Originally Posted by gbent View Post
    If you have ever done this, please explain. How do you push the Pi tape in the hole and get it squared up, and still read the markings?
    I have not measured an ID, only ODs. However Pi Tape makes ID versions down to 3/4" so it must possible to do.
    Sent from my SM-G930P using Tapatalk
  7. #26
    May 2002
    South Central PA
    13,442
    2171
    3367
    This Interapid gage will do it and is accurate to .0001 or less on holes up to 6".
    INTERAPID IRA 2 Comparator Gauge Set 79.111402 - 12-089-9 - Penn Tool Co., Inc
    It's hugely expensive and delicate, I'd hate to send it out on a field job, but it does answer the question. I have one and keep it hidden away until it's absolutely necessary.
  8. Likes TeachMePlease, Trueturning liked this post
  9. #27
    Mar 2005
    Kansas
    7,410
    424
    3393
    Quote Originally Posted by Silent_Man View Post
    I didn't realize there were id Pi tapes. After watching their video, it looks like they are using an internal step to square the tape. That would be doable with a snug fitting split cylinder or a welders wrap a round. Having to read the tape with a mirror due to the boring bar being in the middle looks to be a greater challenge.
  10. #28
    Jun 2019
    South Dakota
    46
    14
    9
    use a small mirror held at an angle ( think dental mirror) there are sold in a wide variety of sizes shapes and lengths from nearly all hardware stores, auto parts stores and tool suppliers. they also work great to find that socket that fell into never never land.
  11. #29
    Jul 2008
    South Carolina
    626
    218
    371
    Quote Originally Posted by Mud View Post
    Correct me if I'm mistaken, but wouldn't the cutter bar interfere in getting a proper measurement?
  12. #30
    Apr 2010
    Wisconsin
    6,010
    4154
    3661
    The Berco gauge is the better way. However, before I had that luxury I milled two flats on the bar and used internal mics between the bar and the bore. ( measure each side to accommodate for being sprung ) Lacking that, adjustable parallel against the flat on the bar with a pin against the bore. Add the adjustable parallel and the pin for total gap.
  13. Likes Trueturning liked this post
  14. #31
    May 2002
    South Central PA
    13,442
    2171
    3367
    Quote Originally Posted by Hodge View Post
    If you can't reach in with that, you can't reach in with spring calipers either. There are shorter contact tips in the kit if those are too long to clear the bar.
