What is the best use of this Kaeser air filtration set up ? (photo)
Results 1 to 5 of 5
    Dec 2000
    Coastal Dogpatch, SC, USA
    51,660
    3081
    5962
    Default What is the best use of this Kaeser air filtration set up ? (photo)
    Was originally used with a CMM... in conjunction with a small IR refrigerated air dryer. Curious why the long membane filter part (which sells for over $1,600 !) would be needed when one would think the air would be dry enough with the IR unit alone. Or was it all about getting the ultimate clean dry air ?
    Nov 2004
    SLC, UT
    798
    1130
    210
    Quote Originally Posted by Milacron View Post
    Those are likely for getting rid of oil vapor- refrigerated air dryers/filters typically do not remove vapor level oil which can haze glass scales often used on CMMs.
  3. Likes gregormarwick, digger doug liked this post
    Feb 2007
    Aberdeen, UK
    4,538
    1656
    2107
    Quote Originally Posted by Colt45 View Post
    Yes, this. It's an oil filter not a water filter.
    Oct 2010
    Oregon
    5,680
    5517
    2156
    Huh. I thought membrane dryers were specific to water vapor. And it does say "membrane dryer" on it, not "membrane filter".
    Nov 2004
    SLC, UT
    798
    1130
    210
    The filter on the left is a KOR-35 model, which is specifically for filtering oil vapor. The membrane filter/dryer on the right is usually installed upstream to remove water and other contaminates (including some, but not all oil) and acts as pre-filter to the KOR, which is more efficient and economical installed in this manner as water vapor will overload it.
  7. Likes gregormarwick, digger doug liked this post
