What are bits for flat-bottom holes in metal called?
Results 1 to 14 of 14
    Sep 2016
    19
    19
    Question What are bits for flat-bottom holes in metal called?
    I need to drill flat-bottom holes with a drill press and I can't find any bits designed to do this in metal. What are these bits called?
    Apr 2010
    Justin, Texas
    338
    97
    Counterbores. You will need to drill the hole to near finished depth and then run the counterbore down to finish it.
  3. Likes dbooksta liked this post
    Dec 2008
    New York
    10,033
    2609
    Quote Originally Posted by dbooksta View Post
    flat bottom drill bits. my company has many sharpened that way and left that way. when sent in for resharpening they are left as flat bottom drills. if we need one a siz we do not have we have to tag it please resharpen as flat bottom drill. they need a hole already made. they only machine the cone shape flat at bottom of a hole
  5. Likes Mcgyver, tdmidget liked this post
  6. #4
    Nov 2011
    Missouri, USA
    2,123
    1354
    2721
    In a pinch, assuming common diameter, a pilot hole drilled, then finished with an end mill plunge-cut can get it done.
    Not sure if you're talking about production items (seems you'd probably not have to ask about flat bottom hole making if you were setting up production, so I assumed you are not) or just making a thingamajig one-time.
  7. Likes dbooksta liked this post
  8. #5
    Apr 2012
    AR, USA
    952
    20
    172
    Apparently, OSG makes flat bottom drills. They claim that they won't walk off center, can drill half a hole on an edge and at regular drilling speeds. They are limited to 2xD though.
  9. #6
    Norfolk England
    2,099
    2487
    1547
    What about a centre cutting end mill,what the UK calls a slot drill.
  10. #7
    Jan 2009
    "Stuck in Lodi", Ca
    3,084
    1850
    1625
    Quote Originally Posted by JNieman View Post
    This method is one that I've used a lot but it did cause me some problems once. The call out was for a flat bottomed hole that allowed for a small chisel point in the center when generating the drilled hole before flat.
    However, I got myself into trouble once doing that and parts had to be reworked. This was because the small reverse taper on the face of the end mill was more than the flatness call out IF I did not use the minimum chisel diameter they allowed for on the print.
    Ironic, a smart designer trying to help knowing about the end mill use allowing the chisel point and we screw it up!
    Their CMM caught the error. Fortunately, as I said, they were fixable and now I always circular interpolate flat bottom holes with a small enough end mill to avoid that.
  11. Likes Spyderedge, JNieman, TDegenhart liked this post
  12. #8
    Dec 2008
    New York
    10,033
    2609
    flat bottom drills i use are sharpened flat on bottom. they do require a hole already there. i often see 20x length to dia ratio flat bottom drills.
    any tool whether drill or end mill and be resharpened flat on bottom but you have to specifically ask for it.
  13. #9
    Sep 2013
    Ohio
    346
    196
    176
    Allied Machine and Engineering Corp. sells flat bottom spade drills.
  14. #10
    Sep 2016
    19
    19
    Just need this sort of thing for one-offs and prototyping. Often I'd be quite happy with a brad-point bit, but I can only find those for wood, and even then they often have an angle (often slightly inverted) on the flats around the point.
  15. #11
    Feb 2017
    Ohio
    22
    9
    Quote Originally Posted by bw_4000 View Post
    We do have Flatbottom drills from 3/8- 2-9/16 for T-A's and up to 5" diameter as a universal spade. The OP does not specify diameter or depth of the hole, so I am not sure what to offer. While you can drill from solid with these tools, it is better to drill almost to depth with a regular drill and just finish the flat.
  16. #12
    Jun 2012
    Michigan
    9,935
    3356
    3559
    (Alied)
    [Flat Bottom (FB) Geometry Flat Bottom Drill Inserts Made Under U.S. Patent No. 6,135,681 Euro Patent No.: 1 210 196 DE,GB,IT,FR Canadian Patent No: 2,341,367 Other International Patents Pending Allied’s Flat Bottom geometry is used to flatten, or square, the bottom of pre-existing holes. Tools with this geometry are normally sized the same diameter as the hole.]However, this style tool (when used with short length holders) may also be used to counter bore holes smaller than the tool diameter. The patented geometry provides
    efficient and stable cutting action. For a Flat Bottom Drill Insert without chipbreakers, please specify using -FN. Available in the Y through 4 series.
    Grades: Super Cobalt, C2 Carbide
    Sample Item Number: 152T-0112-FB]
    Likely any flat bottom drill or the like will tend to walk about at stating on a drill press. putting a flat bottom to an existing hole may be home made with putting a flat to a std drill or bought..An end mill use on a mill can start and finish a flat bottom hole. For production an end mill can be ground dead flat and center cutting with an OD land like a drill of carbide or HSS for very ling life...but with the OD circle land it can only plunge straight in (axial).. it can not plane mill going to the side.
  17. #13
    Jul 2004
    Southeast Michigan
    6,545
    238
    1450
    May also be looking for the term "spot face", where you have a small pilot first since centercutting is harder on tooling and rarely necessary.
  18. #14
    Feb 2012
    Iowa, USA
    673
    2137
    457
    I've always known them as "spring pocket drills" for doing what their name describes in stripper plates.
    We always piloted drilled to a dia. greater than the spring pocket drill's web thickness to full depth then finished with previously mentioned tool. Obviously, this leaves the drill point dimple in the center, which to you may be a no-go.
    The best working ones we ground out of old, shortened-up core drills.
