rimcanyon
- Sep 28, 2002
- Salinas, CA USA
all my horizontal bandsaws do this. im guessing as the blade hooks a chip it twists the blade vertically back and forth, as hook teeth are wider then the 0.030" blade, it allows it to wiggle side to side. the wavy pattern is probably all the teeth spacing equally grabbing a chip then flexing the other way and grabbing a chip on the other side. probably depends on how tight the guides are and spacing along with not getting an equal cut all the way through the bar stock.
It's called "mooning".
I bought a bunch of cutoffs of 410SS. I noticed that every single one shows a strange pattern where it was cut. Not the saw marks but the curves that are perpendicular to the saw marks. Blade vibration, like a standing wave?
Yup. California.
I suspect its caused by the weld in the band not being perfectly straight. That slight bend hits the work and it cuts just a little different. Since it's the same distance apart on the blade, it would make a consistent pattern. Feed rate through the work changes as it gets wider resulting in the curved pattern.
It's caused by the set of the saw teeth pushing the blade/band from side to side in the cut as the teeth enter the work.
Has anyone noticed that the marks are at 90 degrees to the saw cut and parallel to the vise jaws? Try holding the shaft with bolt down device and see the orientation of the crescent shaped lines. I first observed these features around 1979 when I first used and saw cuts make be a horizontal hack saw.
Notice
