11-27-2020, 08:45 PM #1
11-27-2020, 10:58 PM #2
Dog driver for between centers work would be my thought.
sfriedberg liked this post
11-27-2020, 11:12 PM #3
11-28-2020, 01:44 AM #4
Yes, they're just simple drive dogs. They sometimes go cheaper than regular backing plates. Just unscrew the
two dogs and the plate can be used for other purposes...
11-28-2020, 09:13 AM #5
11-28-2020, 09:37 AM #6
11-28-2020, 12:50 PM #7
Is that correct? as I understand it, the # of camlock pins denotes the size, the OP says D1-8 and shows what I'm lead to believe is a D1-6
The ref is used Lathe Spindle Fittings Page 2
11-28-2020, 11:10 PM #8
Some are flush, some stand proud. They are adjusted correct for the install on the lathe spindle.
The Bison chuck is a 200mm, and the mounting pilot interferes with the D1-8 bolt circle.
I think I'm going to leave this as a dog drive, as it's smaller than the face plate I have, for just that purpose.
Rob F. liked this post
11-28-2020, 11:25 PM #9
It is a D1-8, and I don't think the number of the D1 spindle nose size is relative to the number of drive studs.
D1-3, 4 have 3 drive studs, D1-5, 6, 8, 11, 15, 20 all have 6 drive studs. The number is the diameter of the mount. And appears to be a circle of diameter in inches, that the drive studs would just touch.
11-29-2020, 12:04 AM #10
Easy way to tell unknown D1-? sizes, is the diameter of the drive pins. They are different for every D1- size. Also diameter of bolt circle, but if trying to get someone else to measure for you, the pin dia is less likely to get measured wrong.
Side note: Pins can be threaded either metric or english, be sure what threads it is before ordering replacement pins....
11-29-2020, 08:49 AM #11
Thank you one and all, .....probably comes from never being rich enough to have my own camlock spindle lathe
