What is this D1-8 mounting plate for?
Results 1 to 11 of 11
    Oct 2012
    Iowa
    338
    152
    83
    Default What is this D1-8 mounting plate for?
    I got this off eBay to use on a lathe chuck, but wanted to know what its purpose was before putting a pilot of 4mm for a Bison chuck.
    Sep 2009
    Phoenix,AZ
    1,982
    3082
    527
    Dog driver for between centers work would be my thought.
  3. Likes sfriedberg liked this post
    Oct 2012
    Iowa
    338
    152
    83
    Quote Originally Posted by JohnEvans View Post
    I think your right, as if I simplify the eBay search, I see several of these in different forms, all for driving dogs. I just have never seen this sort of back plate before.
    Langley, B.C.
    1,836
    404
    1066
    Yes, they're just simple drive dogs. They sometimes go cheaper than regular backing plates. Just unscrew the
    two dogs and the plate can be used for other purposes...
    Oct 2012
    Iowa
    338
    152
    83
    Quote Originally Posted by LKeithR View Post
    The issue I'm seeing is the threads and ends of the drive cam bolts stand a half mm or so proud of the plate. But I can see cutting them shorter, as the price is right.
    Aug 2012
    California, Central Coast
    5,009
    2368
    2056
    Quote Originally Posted by ignator View Post
    Do you have a different picture? I am not seeing what your describing in the pic posted...
    Sure looks like you unscrew the dogs and turn the pilot - done, I must be missing something.
    Jan 2007
    Norfolk, UK
    20,901
    16341
    16775
    Is that correct? as I understand it, the # of camlock pins denotes the size, the OP says D1-8 and shows what I'm lead to believe is a D1-6
    The ref is used Lathe Spindle Fittings Page 2
  9. #8
    Oct 2012
    Iowa
    338
    152
    83
    Quote Originally Posted by Rob F. View Post
    Some are flush, some stand proud. They are adjusted correct for the install on the lathe spindle.
    The Bison chuck is a 200mm, and the mounting pilot interferes with the D1-8 bolt circle.
    I think I'm going to leave this as a dog drive, as it's smaller than the face plate I have, for just that purpose.
  10. Likes Rob F. liked this post
  11. #9
    Oct 2012
    Iowa
    338
    152
    83
    Quote Originally Posted by Limy Sami View Post
    It is a D1-8, and I don't think the number of the D1 spindle nose size is relative to the number of drive studs.
    D1-3, 4 have 3 drive studs, D1-5, 6, 8, 11, 15, 20 all have 6 drive studs. The number is the diameter of the mount. And appears to be a circle of diameter in inches, that the drive studs would just touch.d1-spindle-nose-data.jpg
  12. #10
    Aug 2012
    5,009
    2368
    2056
    Easy way to tell unknown D1-? sizes, is the diameter of the drive pins. They are different for every D1- size. Also diameter of bolt circle, but if trying to get someone else to measure for you, the pin dia is less likely to get measured wrong.
    Side note: Pins can be threaded either metric or english, be sure what threads it is before ordering replacement pins....
  13. #11
    Jan 2007
    Norfolk, UK
    20,901
    16341
    16775
    Thank you one and all, .....probably comes from never being rich enough to have my own camlock spindle lathe
