MonCeret Gunsmit
- Aug 23, 2018
- E. TN
I/m trying to purge the air(?) From the Vary-Speed unit on this new to me 6913 and can't. Or there is some other issue. ?
I'm following the instructions on the factory plate (Fill unit with fluid at slow speed, hold at 360 rpm for 30 seconds) but the variety-speed dial acts spring loaded---it snaps from 360'r to about 800r's. Rpm's from 800 to max are adjustable as per normal, but under 800 is unusable as it won't stay there when you take your hand of the dial...it just backs up to 800rpm.
Best I can tell I have the upgraded aluminum block down at the sheaves/pulley and the old round unit up at the RPM selector.
Maybe I just have the nut tightened in too far on the aluminum block down on the motor??
Any help or advice would be greatly appreciated.
-MG
-MG
