What is the difference between a Sucker Rod Thread, and a normal thread?
doug925
Titanium
Nov 21, 2002
Houston
I need to quote some parts that have a male .75-10 API Sucker Rod Thread.
What is the difference from a normal thread?
Doug.
Doug.
Doug.
Google it. I did and I conclude its merely a plain vanilla unified thread on a rod the same size.
I've never worked with water wells except to over haul a pump or two. I imagine you select materials and workmanship for a deep well in terms of strength and reliability. A big wind powered well pump 600 ft deep is no exception regardless it being 1870 technology. I'd hate to have to fish out a dropped string of sucker rod and the attached piston.
Thanks Forrest.
I did in Google it. I did not see any specs listed, except those from API. They wanted $92.00 USD to see them! :eek: :eek:
I should have asked if anybody has some spec info they could pass along.
I would rather not have to buy the thread spec, just so I can quote the job.
Thanks again,
Doug.
Thanks Forrest.
Thanks again,
Doug.
Thanks Forrest.
Thanks again,
Doug.
Guys,
Is there anything tricky or extra tight tolerance-wise that I should be concerned about in quoting? (above and beyond a 3/4 10 thread)
Doug.
Guys,
Doug.
Guys,
Doug.
DOH! I needed to re-read Forrest's post...
Never mind....
Think Brain cells, and reading retention,
:D
Doug.
Never mind....
:D
Doug.
Never mind....
:D
Doug.
I found this. There does seem to be a difference.
http://www.weatherford.com/weatherford/groups/public/documents/production/sr_couplings.hcsp
Weatherford offers T and SM grades of Sucker Rod Couplings. Both grades are manufactured with cold worked pre-stressed, roll-formed threads. This round root form is substantially stronger and provides better fatigue resistance than conventional cut threads. The threads of both grades of couplings are coated for anti-galling properties.
Weatherford API Sucker Rods are manufactured to API 11B specifications and are ISO 9001/API Q1 certified in one of the most modern facilities of its type within the industry. These rods feature fully rolled, cold-formed threads designed to provide a precise, smooth, reinforced thread structure not attainable by normal machine-cut threads. Metal is displaced rather than removed and the resultant cold working strengthens the thread root.
