I'm thinking about freely moving armatures in general. I'm wondering what the best way is to make an armature that won't have play in it.
As a basic type of armature, let's say that we have two rods, six inches in length, with H and W both being 1/4". Let's say that in each rod, there is a hole that is drilled width-wise, 1/4" from the end. The rods are now aligned so that the hole of one rod is on top of the hole of another. A clevis pin with a head is inserted through the top rod, then through the bottom rod. Where the clevis pin exits the bottom rod, an e-clip retaining ring is slipped into a groove in the pin, snug up against the bottom rod.
In the above scenario, let's not assume any inherent properties of the assembly, only that it exists as described. In such an assembly, it seems that there are some tradeoffs. The less extra space there is between the rods and the pin, the less play there will be in the assembly. However, the less clearance there is between the rod and the bars, the more difficult the rods will be to rotate about the pin with respect to each other.
Similarly, the more snug the clevis pin is against the rod, the less play there will be, but the rods will be more difficult to turn.
As another variation, the rods could have a Width of 1" instead of 1/4". All else being equal, as a result of increased contact surface between the rods, there would be less play.
What I've described above is one of the most basic types of armatures I can think of. Variations can be made. Bearing raceways could be used. However, if this is done, wouldn't this add radial play to the joint?
Yet another option is, with or without the bearing,to make a ringed depression around the hole in one rod on the side facing the other rod. The second rod will have a ringed extension around the hole on it. This way, when the rods are put together, the ring on the one rod will extend into the depression of the other. It seems that this will limit radial play.
For general purpose building making armatures of a few inches, are there commercial solutions to this problem? If not, what are your thoughts on the methods that I mentioned? Are there any better ideas? Are there any guides that say, "For "x" type of metal, which expands "x" amount per "x" degree Fahrenheit,"x" amount of clearance should be used,"?
This isn't for a specific project. I'm just wondering about this in general.
Thanks.
Thanks.
